last night on the way home from work I pressed my right blinker button and my the red key symbol came on in my speedo and my blinker quit working. any ideas
probably a short somewhere. make sure you dont have any pinched wires or anything. prob in under the rear fender or around the controls. check your fuses to see if you popped the one for the blinkers and that should get your speedo back going, but dont press the blinker again until you find the problem. mine shows the red key symbol now when i press the blinkers because i cut the wires on them. also my friends sportster did the same thing last week. he had a pinched wire in around the controls.
your turn sigs are controlled by the same unit that controls your security system (if you have security), the TSSM.
There is some weird electrical voodoo going on in that box at times that can lead you on a wild goose chases. As already stated, check ALL the simple stuff, bulbs, fuses, broken wires where they can be easily inspected etc etc. The TSSM is an expensive unit to replace, or can be embarrassingly expensive to have the dealer diagnose a crappy fuse for you.
ask me how i know...
additionally somewhere on the forum is a list of error codes, you could save yourself some *** chasing by checking for an error code.
