still have vibration after dealer "fix"
OK. I got the 1K service done, and had all the extras fixed, like the 25 degree injectors (but i'm not sure they remapped the ECM), the handlebar risers tightened, controls leveled (they were >1" different between left/right hands), and supposedly they fixed the vibration.
they didn't. it was specified as an rpm-related vibration, and their fix was to true the front wheel. I figured the rpms for the speed the vibration starts and thought maybe some people here might know some likely causes. in all gears, starting at about 2400-2500 rpm, there is the high-speed vibration I made a post about a couple weeks ago. very hand and foot tingling. I didn't know until tonight what rpm related to what speed in ech gear, so I never rode it out to see if/when it goes away. i'll do that next time I ride it. also, it is MUCH more noticeable when I let off the throttle.
I'll post again when I find out if/when it goes away higher in the rpm range. In the meantime, does anyone have a similar vibration or any thoughts on this?
I can take it to any dealer for warranty issues, correct? I may try getting another dealer to make any necessary warranty repairs if i can.
RE: still have vibration after dealer "fix"
ORIGINAL: Wide06
Is your bike an 06 or 07 model?
Have you checked the ALL the motor mounts?
Does your "check engine" light ever come on?
Do you hear a whining sound coming from the transmission?
Do you have trouble "finding nuetral"?
Does the vibration occur, or is it as severe when the clutch is disengaged?
Does it vibrate in nuetral?
Is the vibration as bad in nuetral?
Is the vibration always there? (When hot/ when cold, etc.)
DougJ
ORIGINAL: DougsDyna
Some questions:
06
i looked at them. i see no loose hardware.
never
no
no
yes
yes
yes
yes
DougJ
Some questions:
06
never
no
no
yes
yes
yes
yes
DougJ
I started it, brought it to 2500 in N, clutch disengaged.
2500 in N, clutch engaged.
2500, in gear, sitting still, clutch disengaged.
on the road, the vibration shifts from the grips and pegs to the seat around 2800 or so, and does not go away after that, but does get faster with engine speed.
if I get to problem speed (like 28+ mph in second) and disengage the clutch, vibration goes away as engine idles down.
all of the above tells me that it is somewhere from the clutch forward.
I checked the best I could. none loose or damaged.
I wonder about alignment though. it SEEMS, if I remember correctly, that the front forks are turned ever so slightly in relation to the fuel tank when I'm going straight down the road. could I be seeing things, or does this point to an alignment issue?
