vibration
Old May 19, 2008 | 01:44 AM
lou1's Avatar
lou1
Default vibration
Hey
I have a bad vibration between 50 and 60 mph. It is even worse when I am accelerating or going up hill. It seems to be coming from the engine but I am not positive. Any suggestions?
thanks
Lou
Old May 19, 2008 | 01:53 AM
LoneRyder's Avatar
LoneRyder
Default RE: vibration
Mis-adjusted clutch?
Old May 19, 2008 | 04:59 AM
Teek's Avatar
Teek
I dunno. If I'm only going 50 mph and want to accelerate, I'll usually kick it down into 4th. If I'm going uphill, the bike wants to do it in 4th at 50. 60's no problem though. Normal straight line steady riding at 50-60 in 5th I don't have much vibration, but I do have some. I usually downshift into 4th below 50 anyway. I'm just simply saying that on MY bike anything below 50 I'm in 4th gear. If the engine is lugging, there's gonna be vibration. And I'm not saying it's normal. It's just normal for me and my bike.
Teek
Old May 19, 2008 | 08:05 AM
capttawes's Avatar
capttawes
Check your motor mounts. Looser than spec.rubbermounts at some RPMs cause vibration.
Old May 19, 2008 | 09:32 AM
agedwards63's Avatar
agedwards63
yes rubbermounts first place to check I agree
Old May 19, 2008 | 11:49 AM
tiger_rider's Avatar
tiger_rider
Do you hit the vibration at the same speed in any gear, or is it at different speeds depending on which gear you are in?
Old May 19, 2008 | 01:16 PM
hogsport's Avatar
hogsport
Like a couple others mentioned, without all the info (model/yr) it sounds like a 5spd 1200 running in 5th and lugging. My bike does not like to run in 5th under 65 or so, especially if there is any grade or headwind, sets up a vibration like you mentioned. - I look at it as a good reason to go 65+ or downshift into 4th. FWIW, this is contrary to the manual.
Old May 19, 2008 | 02:03 PM
JosephGarcia's Avatar
JosephGarcia
dont shift your gears so fast. stay in 4th until 55 or 60.
i only have 4 gears, but i stretch my 3rd into 60 mph before i shift.
Old May 19, 2008 | 06:25 PM
SpursDarkrider's Avatar
SpursDarkrider
man a 6th gear would be nice on our sporties
Old May 19, 2008 | 08:31 PM
CapnAdventure's Avatar
CapnAdventure
I see in your profile you have a 1200. If you're in 5th, then you're lugging the engine...=vibration. Shift to 4th and all will be good.
[IMG]local://upfiles/48168/DEF41A2B26D04EF587A387B585156109.jpg[/IMG]
