Screamin Eagle 103 Low End Torque
Old Aug 5, 2011 | 09:08 AM
Blakerea's Avatar
Blakerea
Default Screamin Eagle 103 Low End Torque
I put the 103'" stage 4 on my bike and D&D fat cat. Right around 110 hp. I love the way it runs, but I am looking for some more low end torque. Any suggestions?
Old Aug 5, 2011 | 09:18 AM
Good_Apollo's Avatar
Good_Apollo
What cams are you running?
Old Aug 5, 2011 | 09:32 AM
WG2011's Avatar
WG2011
Post your engine upgrades that may help you get some info on how to add some low end without that tough to give advice.
Old Aug 5, 2011 | 09:44 AM
O-Town D's Avatar
O-Town D
"I put the 103'" stage 4 on my bike and D&D fat cat. Right around 110 hp. I love the way it runs, but I am looking for some more low end torque. Any suggestions?"
One way to increase bottom-end torque is to change the size of the compensating sprocket in the primary; going smaller will give better low rpm power but with a sacrifice in overall top speed (MPH).
Old Aug 5, 2011 | 09:59 AM
thedonthere's Avatar
thedonthere
This is true but it is less expensive if you change your front pulley from the stock 32 to a 30
Old Aug 5, 2011 | 10:13 AM
Blakerea's Avatar
Blakerea
It has:
Screamin' Eagle Pro Stage IV Kit - 103"
Screamin' Eagle Performance 110+ Heads
high-compression forged aluminum 10.5:1 pistons
Screamin' Eagle 260 cam
Perfect-Fit Pushrods
58mm EFI throttle body
big 3-7/8" diameter highlighted cylinders
Super Tuner
58mm Screamin' Eagle Heavy-Breather
Automatic Compression Release
Screamin Eagle Performance Clutch Kit
D&D Fat Cat 2 into 1
Old Aug 5, 2011 | 11:03 AM
O-Town D's Avatar
O-Town D
Originally Posted by thedonthere
"This is true but it is less expensive if you change your front pulley from the stock 32 to a 30"
You're right, and probably less fuss and muss!
Old Aug 5, 2011 | 11:58 AM
pete62conv's Avatar
pete62conv
With the combination of the heads and big throttle body you really hurt the intake runner velocity (bottom end). You pretty much sealed your fate. The best thing to do is listen to everyone here and drop at least two teeth off the front. I would not be afraid to go more teeth off the front as these things are geared to the moon.
Old Aug 5, 2011 | 07:23 PM
Blakerea's Avatar
Blakerea
How would a 30 tooth pulley affect me at high speeds? I know I probably be able to go as fast but I am not trying to run at top speed. Will this get my rpms real high at higher speeds? Will it matter? Sorry I am new to this
Old Aug 5, 2011 | 08:46 PM
greybeard6005's Avatar
greybeard6005
I'm in the same boat as you Blake. Thought about changing out the cam and started a thread about it.
https://www.hdforums.com/forum/engin...ge-4-cams.html
Haven't made any additional mods yet - actually getting used to it at this point, but its taken about 3K miles to really learn the engine (admittedly, I'm a slow learner)
Other than the low end, I love the way it runs!
elky72ss454
Milwaukee Eight (M8)
Jan 6, 2017 08:03 PM
JockWhisky
Exhaust System Topics
14
Oct 15, 2013 10:18 PM
gregsdart
Jun 8, 2009 06:35 AM
PowerJunkie
Mar 24, 2008 08:52 AM
eddybo69
Jul 25, 2006 03:26 PM
