Fuel pak codes
Old Aug 11, 2011 | 08:33 PM
stbobshadow's Avatar
stbobshadow
Default Fuel pak codes
Found out today that the settings i had in my fuel pak that was on the origional instruction were differant on their website in which they also suggested using the website settings. The question i have is with the wrong settings in the fuel pak would that cause it to cut out during low speed excelleration intermitantly?
Old Aug 11, 2011 | 09:26 PM
nevil's Avatar
nevil
Quite possible. Use the other settings and see if it makes a difference.
Old Aug 15, 2011 | 08:51 AM
Slipstrm's Avatar
Slipstrm
They changed the settings awhile back, the new ones are far better than the original ones.
Old Aug 15, 2011 | 10:10 AM
saw*me's Avatar
saw*me
They update maps from time to time based on user input. Check on the site and use the newest version and see how it works for you .
Old Aug 29, 2011 | 06:59 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
So, had some wrong codes loaded in mine for a bit now...found the right ones and did make a difference! Think things are okay? screw things up with the wrong codes?? Getting better throttle response, ALOT less popping..feels alot better, just hope did not mess anything up!
16VAFXDL
Exhaust System Topics
Sep 11, 2010 05:36 PM
drillinbig
Jul 28, 2010 01:35 PM
pauletich
Jun 8, 2010 04:43 PM
Bamboo
Feb 23, 2008 03:07 PM
