dyna wheel bearings
Old Aug 27, 2011 | 09:40 PM
agliderider's Avatar
agliderider
Stage II
Angry dyna wheel bearings
I am another rider that has had wheel bearing trouble on my 09 super glide custom. I took it in to dealer with 9,700 mi and had rear tire replaced. took it back in 1 week later for the 10,000 mi service. I rode it about 3 weeks and the rear wheel bearing locked up and broke the hub on wheel. Had to argue a bit but harley did cover the wheel. My extended warrenty covered the bearings. But the dealer wants me to pay them $85.00 to put tire on new wheel and pay for a spacer. I am thinkn HARLEY NEEDS TO BUCK UP AND RECALL THEESE BEARINGS BEFORE SOMEONE GET'S HURT OR EVEN WORSE KILLED. I am telling you it happened very fast and NO WARNING. IS THERE ANY BODY OUT THERE KNOW WHERE I AM COMMING FROM ???????? THANK'S FOR LISTENING TO ME !!!!!! RIDE SAFE
Old Aug 27, 2011 | 10:28 PM
blacknsilver's Avatar
blacknsilver
My rear bearing went out on my 09 Fatbob with about 10,000 miles 2 weeks shy of my 2 year warrenty. Bike started getting a wobble while me and the wife were on a ride and pulled over. Didn't mess up the wheel but the dealer replaced it under warrenty that same day. Must have been a bad batch of bearings because 10,000 miles does not seem like much.
Old Aug 27, 2011 | 11:30 PM
stilup's Avatar
stilup
These are supposed to be 100,000 mile bearings!
I see recommendations to change bearings at every other tire change but 10 thousand miles is way too early.
What crap are we riding on?
Old Aug 28, 2011 | 01:36 PM
Mr. Lucky's Avatar
Mr. Lucky
Harley has been at this a long time. I have to believe that at least some of these failures are due to installation error after replacing tire... axle nut too tight, spacers swapped, etc.
Old Aug 28, 2011 | 01:46 PM
stilup's Avatar
stilup
Good point on the torque but bearing failure seems to happening much too early in this forum.
Who has the better bearings to install.
I see low cost bearings on Ebay but something as important as the bearings demands the best.
Any ideas who has the best bearings for this application given the existing bores.
Old Aug 28, 2011 | 07:43 PM
agliderider
Stage II
Question Torque spec
Anyone know what the correct torque spec is for rear axle nut on a 2009 super glide custom? THANK'S
Old Aug 28, 2011 | 09:16 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
The low cost bearings work as well as the stock HD ones. How could they be worse? 100,00 miles turns out to be more like 40,000-50,000 in the real world.
hardwork2
Milwaukee Eight (M8)
Jun 2, 2019 05:15 PM
Donnylee
Dec 20, 2017 11:55 AM
jlandis874
Aug 12, 2011 04:08 AM
twally
May 20, 2011 05:57 AM
07JakeelwoodHD
Aug 9, 2010 10:17 AM
