Front tire centered?
Old Sep 4, 2011 | 08:47 AM
8541hog's Avatar
8541hog
Originally Posted by panelbeater
The spacers are different sizes, that being said if your brake pads arent rubbing your disc the spacers are installed correctly. So no your wheel is not centered because its not supposed to be. Tweak the fender over til it looks right and go riding.
Please show me where it says ANYWHERE that the front tire is not suppose to be centered.
Old Sep 4, 2011 | 09:04 AM
mang0's Avatar
mang0
Originally Posted by 8541hog
No, that's not just for dual disc wheels. That is the main purpose of that hole, how else would you make sure the axle is aligned properly?
just looked at the manual...only mention of the axle hole is to place screw driver in it to hold in place while you torque axle nut....which I did and it never
drew it in that far..leave it to GS, to make it vague
Old Sep 4, 2011 | 09:07 AM
mang0's Avatar
mang0
GS is supposed to be HD, this smart phone ain't al that smart sometimes
Old Sep 4, 2011 | 09:10 AM
panelbeater's Avatar
panelbeater
Please show me where it says ANYWHERE that the front tire is not suppose to be centered. That is just asinine.
I edited that from my post after rethinking it wasnt the wg but in 07 harley put out fl softails with the front wheel offset. No ****!!
Old Sep 4, 2011 | 09:23 AM
8541hog's Avatar
8541hog
Since mine is an 05 they may not be the same, but the axle has a shoulder to stop the spacer on the throttle side, you can see a small gap between the slider and spacer in the pic below.
IF you tightened the throttle side clamp at all before tightening the axle nut it would draw the slider closer to the wheel instead of drawing the axle through the slider. That is why you have the screwdriver or whatever in the hole so it stops at the slider.
This is why I asked about stiction on your sliders, if it is not aligned properly it can cause the sliders not to slider properly.
The wheel should be centered if the alignment was done correctly.
Old Sep 4, 2011 | 01:43 PM
mang0's Avatar
mang0
My Buddy had that gap and (not knowing it is supposed to be there or that there was a shoulder to stop the slider from moving freely) loosened the axle cap and moved the fork leg over (towards the tire) and snugged it down to take up the space. I will have to let him know so he can adjust that.
But wondering if the original poster's 07 has that "space" and that is what the indy had done...?
Old Sep 4, 2011 | 02:28 PM
8541hog's Avatar
8541hog
Originally Posted by mang0
... I will have to let him know so he can adjust that.
I have been told that space keeps the spacer from damaging the 2 piece clamp setup on that side.
If he doesn't have that space his front end should ride like a rock compared to a proper setup.... Don't ask me how I know this....
Old Sep 4, 2011 | 02:39 PM
mang0's Avatar
mang0
Appreciate the info 8541 hog
Old Sep 4, 2011 | 09:59 PM
Steel Steed's Avatar
Steel Steed
The front wheel will spin, but there is a slight rubbing sound. Not sure if that's normal, or not though.
nosparkoflife
Nov 25, 2013 03:36 PM
JoeGrapes
Jul 30, 2012 06:41 AM
WhiskeySierra
Mar 3, 2012 12:20 AM
chappy99
Jan 15, 2012 02:56 PM
roccitybiker
Jul 3, 2010 06:58 AM
