98 dyna ignition problem helpppp!!!
Old Sep 4, 2011 | 08:58 PM
dew925's Avatar
dew925
Default 98 dyna ignition problem helpppp!!!
While riding down highway ,she just quit ,no noise nothing just lost power.When finally getting trailered home ,Checked it out an no spark.Changed coil,ignition module still no spark any idea's?when changing ignition module plugged it in an turned key on it sparked,but nothing after that.All wiring appears to be good all fuses are good.
Old Sep 5, 2011 | 05:32 AM
dew925's Avatar
dew925
wow thanks for all the generous outpouring of knowledge,really thought i could find some help her fairly quick as i would like too ride it,but can't afford to take it to a dealer.
Old Sep 5, 2011 | 06:55 AM
djack's Avatar
djack
do you have a manual? does the 98 have cam and crank sensors? have you checked the wiring and connectors?oyu really have to do a little troubleshooting or all you`ll get is what you`ve done plug this in ,plug that in, oh it still don`t work. when you go at it that way and possibly buy a bunch of stuff you dont need it may have been cheaper to go to a dealer.good luck
Old Sep 5, 2011 | 07:04 AM
LarryLives's Avatar
LarryLives
Have to ask, did you check the battery connection? a loose terminal will still allow power but wont be a strong enough contact to run...
Old Sep 5, 2011 | 01:37 PM
dew925's Avatar
dew925
Yes I have a manual,all wires an connections seem to be good,tested the coil according to manual an I thought it was bad so I replaced it,same as with module?what could be left the cam positioning sensor?Battery cables are tight ,ground wires are good an making good contact.
Old Sep 5, 2011 | 03:37 PM
jamman's Avatar
jamman
got all the idiot lights on and all that? still lookin for a broken shorted or loose wire..
Old Sep 5, 2011 | 04:21 PM
djack's Avatar
djack
Yep the cam and crank sensor,or connection,are you getting voltage to the coils?
Old Sep 5, 2011 | 06:02 PM
dew925's Avatar
dew925
Yes I'm getting voltage too the coil,just no spark.
Old Sep 5, 2011 | 09:26 PM
dynamac's Avatar
dynamac
Try the crank position sensor. When mine went the bike just died. I still got lights but the bike wouldn't turn over. It happened a couple of times before it was completely shot. Really easy to change. Good luck.
Old Sep 5, 2011 | 10:03 PM
redrubicon2004's Avatar
redrubicon2004
One thing to keep in mind is that while this is the dyna section, 85% of the members who visit this section are twin cam owners and dont have much first hand experience with EVO's
