OUTER PRIMARY COVER
Old Nov 25, 2006 | 03:09 PM
vze4gqv6's Avatar
vze4gqv6
Default OUTER PRIMARY COVER
I have a 2006 Dyna Super Glide, I am new to riding, my first bike was a 2003 1200xlc. I let the dealer do all the work I was afraid to touch the bike. I would like to start working on my own bikes. Is it a big project to change the outer primary cover. It does not appear to be. Any suggestions would be greatly appreciated. I am somewhat mechanical. I have worked on my own cars.
Thanks
Old Nov 25, 2006 | 03:23 PM
AZ Rider's Avatar
AZ Rider
Default RE: OUTER PRIMARY COVER
I put on a chrome primary cover on my Super Glide with no problems. If you can turn a wrench, you can replace the outer primary easily. The shift lever and foot peg have to be removed first. Just a couple bolts to loosen. Then loosen all the fasteners on the primary. When installing the new outer primary, make sure you follow the bolt tightening sequence in the instructions. Also be sure to drain the primary oil and have a new gasket on hand.
Old Nov 25, 2006 | 03:31 PM
vze4gqv6's Avatar
vze4gqv6
Thanks, will do
Old Nov 25, 2006 | 06:54 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Don't forget to loctite the fasteners and torque to spec.
Old Nov 25, 2006 | 07:05 PM
KeithB's Avatar
KeithB
yeah , very easy job
Old Nov 27, 2006 | 08:51 AM
carltex's Avatar
carltex
If you are goin to be doin some wrenchin yourself best invest in an in/lb and ft/lb torque wrenches. You will need both sooner or later. Also, get a set of torx head sockets. You will need a #27 torx socket to install the derby cover. A #25 will not work, I tried.
Old Nov 27, 2006 | 09:18 AM
irlm1's Avatar
irlm1
for definite get yourself a copy of the service manual also.
theyre on ebay at good price from lake shore HD.
it will give you all the torque values, and tips such as which sequence to tighten in etc so that you do not warp anything.
Old Nov 27, 2006 | 11:02 AM
AZ Rider's Avatar
AZ Rider
I actually replaced those torx derby cover screws with five hex fasteners. Much better and easier to take off now. Darn near stripped two of those torx screws so I replaced them.
Old Nov 27, 2006 | 06:22 PM
stubby's Avatar
stubby
Ask around and find a cover that is tight fitting. A poorly made cover will leak, and that's no fun. Also, AZ Rider is right on with bolt change.
Old Nov 28, 2006 | 04:07 AM
carltex's Avatar
carltex
Where would you get the bolts at, the dealer? I know hex bolts would be an improvement.
ORIGINAL: stubby
