Need opinions, What do you think?
By the way, thanks for all the honest replies, I appreciate everything that is being said, keep it coming.
I notice that the radius at #3 does not quite flow with the rest ... I would recommend it be worked to fit the curve of the rest of the fender if you are staying with a round, semi-circular shape for the fender sides ...
I drew the possible outline of another line #4 that picks up something of the feel of the stock fender outline ... I think some further shaping might make the fender more attractive ....
... Just my 'two cents' ....
R/
'Chop
After giving it a little thought, you could flatten the front of the fender where it meets the frame downtubes ... I did that with the rear fender I adapted for use on my bike ....
That would move the entire fender forward a little ....
Another thought is that you should make sure there is enough clearance for the angle cut above the upper belt guard ... as the shocks compress there's a risk the guard will hit the fender ... don't ask me how I know ...
Some trimming there should allow you to slide the fender forward, making the fit much better.
It does look better with some of the sides taken out though.
