gas smell from air filter
Old Oct 23, 2011 | 11:55 PM
gartec81's Avatar
gartec81
Default gas smell from air filter
so installed fuel moto air filter.
there is no place to route the breathers? so they are venting to the air. noticed some light grey smoke from the cleaner today and realize its the breathers just doin there job. but since its vented to the atmosphere I smell it.
What did I do wrong on install. how can i fix this?
Old Oct 24, 2011 | 12:04 AM
gartec81's Avatar
gartec81
maybe a external crankcase breather... what have you all done?
Old Oct 24, 2011 | 05:55 AM
bikebuilderdude's Avatar
bikebuilderdude
If it is the correct air filter for your bike, there should be two holes for the breather tubes to go into. Can you post a picture of what it looks like?
Old Oct 24, 2011 | 03:31 PM
Foxster's Avatar
Foxster
Here's a piccie of the Fuelmoto A/C from their site:
They say its an SE backplate, which means that if its installed correctly the breathers port output is fed up the hollow bolts and into the tubes cast into the backplate and out the holes near the carb/throttle-body intake i.e. not to the air.
Old Oct 25, 2011 | 05:09 PM
gartec81's Avatar
gartec81
ya im a dummy. the black tubes connect to were they were before and are routed into the air filter. you do that before you put the filter on. not after. thats why i couldnt see a location for the breather tubes to go. it was also dark out and with minimal instructions. daylight does wonders.
lol but now i have ripped a breather tube. used the stock tube and cut the fuel moto one so it pushes the stock tube in palce. works for now. need another tube from fuel moto
Old Oct 25, 2011 | 07:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'd be a little concerned about that one tube coming lose and finding it's way into the throttle body , manifold or worse, the combustion chamber.
Old Oct 25, 2011 | 07:38 PM
gartec81's Avatar
gartec81
well its the stock tubing that was originally there before the filter and backing plate change. so it still grabs just like it did before i took it off. i ripped the fuel moto tube not the stock one. i just shoved the fuel moto grommet in there for some extra support. more so it was a tight seal, plus the filter also holds the lines down in place.
but truthfully I didn't even think of it coming loose enough the go into the combustion chamber.
LCCXL1200X
2014-2024 Touring Models
Feb 6, 2016 11:28 PM
tim_espana
Dec 12, 2014 10:46 PM
RiverSouth
Aug 28, 2014 06:39 PM
reclaimer53
Sep 12, 2011 07:12 PM
jeeper53
May 14, 2006 11:07 AM
