Street Bob vs. Night Train
Shifting: No idea why your SB is clunkier shifting. My SB w/ forwards shifts smooth as silk. No difference between the two bikes. Different primary oil perhaps? Also, check to make sure your shifter linkage moves with no obstruction.
Steering/Cornering. The SB has way less rake than the NT. This means the NT is stable as a freight train in the straights, but takes more steering input to turn. The SB will be more "twitchy" meaning it takes less steering input to turn. As far as having to "I feel like I need to hold on or else." Unless your bike is screwed up, you probably just need to get used to it. I've ridden my SB for miles no-handed on the slab, and it doesn't feel unstable at all to me.
Forward controls: The dyna forwards have you way more stretched out than the softail ones, that's why they feel different.
Clutch: I believe it was 2006 that Harley put a new clutch spring in the big twins, resulting in easier clutch activation. The cable on your NT may have needed lubrication also.
Throttle: The NT had drag bars on tallish risers, resulting in much more of a stretch to the grips. I actually have run that setup on all my bikes, as I have "monkey arms" that need to have the bars forward for a comfortable position.
Braking: I think HD may have upgraded the brakes between 2004 and 2007. Also, the SB is a lighter bike, but not by a lot. (around 10lbs)
Overall Handling: As far as the NT feeling more balanced at a stop, the NT seat height is 25.2" and the SB seat height is 28.8" More than an inch and a half lower for the NT which is a huge difference when balancing the bike.
I hope you come to like your SB, and have may enjoyable miles on it.
Crazy
Nt a flame at you at all, just I think it'd help us all if you told us what youre looking for in terms of responses.
I made the switch from a heritage/fatboy to my street bob but it'd be useless to compare them as the softail was a carbed evo 5 speed and of course the dyna is an efi twin cam 6 speed.
As you can see, the bikes are set up completely differently as well...making comparisons even more useless.
Not everyone is comfortable on my bike, but I am and that's all that counts. The rideis hard, im slammed down low on a stripped barebones seat, my bars are high, pipes are loud, forward controls, on and on. But I set it up for me not anyone else.
Again, I'm not much help as I don't know if you were looking for opinions, if you were endorsing the dyna, or what...but that's my experience
I should have jumped on my Street Bob right after riding the Night Train before I posted this thread. I can honestly say I now operate my Street Bob more confidently and nearly everything seems easier and more comfortable. I am sure many of you have experienced this as well when going from one bike to another.
This forum is great!
@toastman: no worries. I posted the thread just to share my experience. I asked for input here and there and got exactly what I wanted.
Here in Iowa it will hit 70 degrees fahrenheit today! Tomorrow: 52 degrees!!! Comfort season is almost over. I need more thermal clothing ;-)
Like rounder said, it sounds like you need to make a few front end adjustments to your bike.
I've locked the throttle at 75 and taken my hands off the bars without giving it a second thought.
52 is still sweatshirt weather. Break out the cold gear when it's 32 lol.
If you want clunky gear changes you should try a BMW. I had a ride on a boxer and that really had a bad gear change.
