exhaust leaks
Old Oct 26, 2011 | 05:45 AM
stbobshadow's Avatar
stbobshadow
Default exhaust leaks
Will the exhaust gaskets just go bad mine makes the hiccup sound more so lately whe excellerating when its cold and wondering if they might be the problem. They were changed from the originals when i changed the exhaust.
Old Oct 26, 2011 | 06:13 AM
LarryLives's Avatar
LarryLives
Never heard of them goin bad, but keep in mind the nuts should always be tightened / checked...
Hot to cold, over time they will prob need a 1/2 turn. JMO
Old Oct 26, 2011 | 11:31 AM
8541hog's Avatar
8541hog
Very true, be sure to tighten them cold only.
Old Oct 26, 2011 | 12:25 PM
nevil's Avatar
nevil
I got tired of the nuts loosening up and once even falling off so I double nut the studs. Never will get loose again.
Old Oct 26, 2011 | 01:09 PM
stbobshadow
Will that cause it to hiccup(cut out) when excellerating
Old Oct 26, 2011 | 07:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Typically a cold EFI engine shouldn't "hiccup" on acceleration. With an open intake there is more cold air going done the intake. Have had the EFI tuned for the intake?
Old Oct 26, 2011 | 07:40 PM
8541hog's Avatar
8541hog
HUH?? A cold carb will, but I have never had a cold EFI motor show that characteristics, EFI should prevent cold stumbles, that is why it has no choke like a carb does.
mupepe
Feb 23, 2015 09:26 PM
otter8
Mar 29, 2011 06:09 PM
craigffb
Aug 17, 2010 02:43 PM
mborn41556
May 26, 2009 12:07 PM
Sporty12C
Aug 31, 2006 06:51 PM
