Not just cosmetics, also suspension, FXDX has fully adjustable rear and front (2000-later) suspension
Also the front rake is 28 degrees verses (I believe) the standard 32 degrees. This changes the handling and makes it more responsive - at the cost of straight line stability i.e. it wants to turn and requires more effort to go straight
It doesn't suffer at all with straight line stability. It drives very easy and no effort to go straight. I'm not sure where you got that from. If you have one, something might not be right with yours.
I wouldn't trade mine for any other Dyna. It is definitely worth it. However, if you are looking for a low slung cruiser, look elsewhere. The FXDX sits higher than all other Dynas.
I didn't say it "suffered" from straight line stability. What I said was the less the rake the less it wants to go straight. The more the rake (like a chopper) the more stable it is going straight and the less it wants to turn. This is physics - there is a trade-off to the rake. Read about it.
Bottom-line to say it suffers on a FXDX is a judgement and I wasn't judging. I was simply stating the engineering trade-off and that the FXDX has a lower rake.
My 2000 FXDX (see my signature) is very stable and a pleasure to ride. That said it isn't as friendly going down the freeway mile after mile as my roadking is. It isn't just the frame, weight, height etc. Most other harleys have a larger rake than the FXDX and are less effort to tour long distances. However, for the twisties I will ride my FXDX because it flips. Nothing is for free!
Sketch out your design to visualize the frame. Be sure to include the angle of the steering head, the tube that connects the front fork and handlebar to the frame. Depending on the look you are aiming for, this angle can range from a "steep" 26 degree angle for greater maneuverability to a longer, "raked-out" 40 degree angle for extra stability. Keep in mind that there will always be a trade off between handling and stability, so choose your angle wisely.
