harbor freight bike lift
Old Nov 11, 2011 | 10:49 PM
treadstone's Avatar
treadstone
Originally Posted by dynabobster
I have had my Harbor Freight Yellow jack going on 3 years with no problems, works great and rock solid, especially if you do the SC Mod.
Whats the SC mod??
Old Nov 14, 2011 | 02:52 PM
dynabobster's Avatar
dynabobster
Originally Posted by treadstone
Whats the SC mod??
A set of longer bolts that simply moves the lift pads to the outside of the lift pad supports. This allows the lift to contact the frame just below the rear mount and the rails at the front missing the pan guard that is welded to the frame, thus eliminating the need for adapters. Makes for a rock solid lift.
This mod works for both the Sears Red Jack and the HF Yellow Jack of similar design.
https://www.hdforums.com/forum/dyna-...ification.html
Old Nov 14, 2011 | 03:06 PM
PhotoRider's Avatar
PhotoRider
So with the table don't you need another jack to raise the bike to take off a wheel?
The bike is still supported by the tires. All it does is lift the bike up. Understood there is a removable plate under the rear tire, but the bike must still be supported right?
Old Nov 14, 2011 | 06:35 PM
GMDayna88's Avatar
GMDayna88
I also have the yellow jack. It's two years old and still work great. In the winter I raise the bike off the ground and set the lock and that's were it stays till spring. Best $59.00 I ever spent. Glenn
Old Nov 14, 2011 | 06:49 PM
jamman's Avatar
jamman
yes i have a small flat jack from a dodge caravan i gave 5.00 bucks for to lift the front tire and rear on the table.. once you get a table you'll never go back..for anything.. and works for all kindsa things, and the guys that love thier small jacks ( i own one also) have never used a lift table.. cause your f#$%in insane if you think a jack is better..
Old Nov 14, 2011 | 06:52 PM
baust55's Avatar
baust55
i have the yellow HF jack .USED coupon with tax $63 .. i just bought a black widow sissor jack from discountramps.com $54.99+17.99 shipping . waiting for ups to bring it
Old Nov 14, 2011 | 06:54 PM
JRK5892's Avatar
JRK5892
i use pancake jacks... car jacks are too flimsy when it only has 2 contact points
Old Nov 14, 2011 | 07:01 PM
jamman's Avatar
jamman
yeah jr i modified it with angle, and flat stock, i have a welder here, i just wasnt going into detail.. the flat fat jacks are nice, the 3/4 nut on the threaded shaft and a cordless impact , up and down . it goes..
Old Nov 14, 2011 | 07:12 PM
11bDad's Avatar
11bDad
Not to highjack the OP's thread, but I'm comparing the Harbor Freight, Northern Tool, and Craftsman jacks. There doesn't appear to be much difference between them. Do you folks know anything that would make one a better choice than the others?
Thanks
Old Nov 14, 2011 | 07:47 PM
LDB187's Avatar
LDB187
it's not very good for oil changes for me. I bought it so I wouldn't have to lay on the ground to change oil but i seem to have trouble getting a drain pan and tools under the bike w/o lifting it off the table. that can be very tricky or at least for me it is. went back to the ole leverage jack i bought many yrs ago and laying on the ground again. other than that it's a good table to work on. heck I even used it for a buffet table when I had a fish fry out in the garage.
