Wobble?
Old Nov 14, 2011 | 11:33 PM
moto_phil's Avatar
moto_phil
Default Wobble?
I was out riding today for the first time in a week or so. I got out on the highway for a good stretch and when I hit 75mph the front end started wobbling pretty bad. Not enough to loose control or anything but very noticeable. When I would slow down it would calm down but anytime I went over 75 it would do it again. I never noticed this before but the bike only has like 250 miles on it.
Anyone else have this problem? It's a 2012 Superglide. The only thing I have done to it so far is a new seat and highway pegs.
Old Nov 14, 2011 | 11:40 PM
missedem's Avatar
missedem
Mine wobbled a bit after about 1200 miles . I adjusted the tire pressure to spec. and made sure the front end fork adjustment nut was not loose. Since your bike is so new, Id go to the dealer and explain what is going on. That new it probably just needs a small adjustment on something.
Old Nov 14, 2011 | 11:42 PM
soft 02's Avatar
soft 02
Does it have spokes up front. Maby loose steering head bearing. Tire pressure?
Old Nov 14, 2011 | 11:48 PM
moto_phil's Avatar
moto_phil
It is an FXDC with spoke wheels. I will have to check the tire pressure in the morning, I hope that is it. If not I will be taking a ride to the dealer this week..
Old Nov 14, 2011 | 11:53 PM
soft 02's Avatar
soft 02
Start tappin spokes for a thud or two. Its a new bike so things are probably settling in.
Old Nov 14, 2011 | 11:55 PM
missedem's Avatar
missedem
these new dynas do seem awefully sensitive to correct tire pressure and to having the nut on the front end for fall away adjustment stay tight without occasional tightening. they are one of the best handling bikes I have ever ridden but they do need occasional adjusting of small things.
Old Nov 15, 2011 | 12:41 AM
DonN's Avatar
DonN
Its the dreaded high speed wobble. Do all of the above. If it still has the wobble, consider the True Track or similar. Plenty of threads on this topic.
Old Nov 15, 2011 | 01:09 AM
soft 02's Avatar
soft 02
Sorry to jump a thread bu i see your in Manila. Is there a bar there called the hobbit house run by midgets. Had some good times there. Sorry carry on.
Old Nov 15, 2011 | 01:50 AM
DonN's Avatar
DonN
Not that I am aware of, but many strange places in Manila.
Old Nov 15, 2011 | 02:27 AM
grbrown's Avatar
grbrown
I agree with the others, your bike is new, so visit your dealer and play dumb but polite! Persist if necessary, these things do not misbehave like that.
I am a great fan of True-Track kits and they will tighten your bike up a treat, but it needs to be as good as it can be first!
