FXD to FXDL indicator lights
Old Nov 25, 2011 | 05:54 PM
gmanm1's Avatar
gmanm1
Default FXD to FXDL indicator lights
I did the tank swap from 99 FXD to FXDL. Everything worked out except I don't know how to connect the FXDL headlight mounted indicator lights. Could someone who has done this please explain what needs to be done.
Thank you,
Greg
Old Nov 25, 2011 | 08:10 PM
snstiggy's Avatar
snstiggy
I did the conversion from FXD to the FXDL/wide glide console conversion. It turned out perfect thanks to the help of everyone on here.
When I did the conversion I swapped into the 2010 Wide Glide console and used the parts list from SURFOR Chop. I cut the light bulbs off the indicators bought some pins and plug. I bought LED indicators part number 68789-96A and plugged it right in I had just enough room to move my indicator lights into the console. I've seen some people keep the indicator lights in the brow/nacelle above the headlight or set up LEDS in the FXDL console. Try this. I hope it helps
https://www.hdforums.com/forum/dyna-...ml#post7436675
Old Nov 25, 2011 | 08:41 PM
gmanm1's Avatar
gmanm1
Thank you for that. I will give it a try.
copter827
May 16, 2018 06:52 AM
MyBeerBelly
Sep 29, 2016 08:42 AM
moose1982
May 4, 2011 01:04 PM
Ozbernie
Mar 6, 2011 02:36 PM
bassnman
Nov 13, 2007 07:49 PM
