more winter mods
Old Nov 27, 2011 | 07:53 PM
07 dyna man's Avatar
07 dyna man
Default more winter mods
here we go again,, sending out the throttle body to hp. inc getting the full port and puching it out to 48mm. getting rid of the pcIII and going with tts mastertune,,, and i thought i was done,,,lmao! there are guys here with the same power output with the tts and almost double the fuel mileage than me
Old Nov 27, 2011 | 11:16 PM
greenstreetbob's Avatar
greenstreetbob
What are the claims on the port job? I am also considering ditching the pc3. My 2008 StreetBob with the V&H Power Commander, slip ons and Drak air cleaner assembly ran way better than my 2011 SGC with the pc3, Straight Shots and S&S air cleaner..
Old Nov 28, 2011 | 03:21 PM
07 dyna man
if you take the time to uprade your heads, cams, exhaust, etc. you really should do the throttle body because it becomes the choke point of the build, stock harley throttle bodies arent known for performance, i took a look into it when the motor was apart and i could see it needed some work but opted not to do it at that time "MISTAKE" a good port job and a 3mm larger throttle plate will yeild almost 30 more cfm ,and a good set of head will really like that
LazySundays
24
Aug 11, 2018 07:08 PM
FATCAT_01
Exhaust System Topics
Sep 7, 2012 11:25 AM
Born2cure
May 14, 2012 07:05 AM
Dru
Jul 4, 2011 07:20 AM
cccbebad
Aug 13, 2008 10:15 PM
