Porting a throttle body ?
Old May 13, 2012 | 12:20 PM
Born2cure's Avatar
Born2cure
Default Porting a throttle body ?
Doing a 107, would porting the throttle body be benifitial. Had 103 with head work. Bad leak down taking apart going to do 107. Would having the throttle body ported help with power.
Thanks
Old May 13, 2012 | 01:05 PM
blue flht's Avatar
blue flht
I used the stock tb on mine, and T-man said that a ported tb would have shown more hp. But I dont think it hurt the bottem end at all.
Old May 13, 2012 | 01:30 PM
mkguitar's Avatar
mkguitar
maybe, maybe not depending on what the rest of the motor is doing.
1.) a larger TB means lesser velocity which affects lower rpm cylinder fill
2.) it was found on evos that a rough casting on the intake tract actually flowed more air than a smooth bore. like a golf ball, the rough areas held air which acted as a buffer to allow the air in the center of the TB to move more quickly
mike
Old May 13, 2012 | 01:45 PM
Bill03E's Avatar
Bill03E
A match ported will be more efficient no doubt, if the intake ports are not lined up, then you will most definitely gain, but to get it right you need the heads ,and the intake, or mark the intake to where it needs to be opened up.
I have ported heads on a 1600cc buggy engine, he ran it for a while, and then took the intakes off , and had me port them, he said it had power it never had before.
Old May 13, 2012 | 02:18 PM
Ultra61's Avatar
Ultra61
I am having a stage 4 installed on my 2012 that comes w/ a 58 mm TB ...I am installing a 54 mm because I believe the 58 to be to large and bog in-low rpm's...I have no math fact on bikes but on small block such as a 340 if you put a 750 double pump on, you will get bog at lower RPM's when going straight to full throttle. If you put a 650 on, the performance off a rolling bottom take off is much improved. And such my theary...a 113 can barely handle a 58 mm TB. IMHO
Old May 14, 2012 | 01:20 AM
Born2cure's Avatar
Born2cure
Thanks guys. Think I'll leave it. Don't want to lose low end because that's where I like the power.
Old May 14, 2012 | 01:33 AM
mike_oh's Avatar
mike_oh
I am running a 117" with a 58mm HPI TB. I had it matched and ported along with my heads by Dan Vance Racing and it is awesome! Plenty of low end torque early on and is a blast to ride. It all depends on the build. Planing out your build before you start will make you happy.
Old May 14, 2012 | 06:51 AM
troop's Avatar
troop
FM ports/hones the stock TB for their 107" build. Jamie mentioned in some thread here that the stock 50mm TB is big enough for that CI displacement....
Old May 14, 2012 | 07:05 AM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Cam profile will also be a factor in how efficient a throttle body works. The velocity of air flow into your engine can be enhanced with porting work if your looking for high rpm use. I had my stock 50mm ported to a 54mm for my 117". Its always smooth and provide great response at rpm ranges I use when riding.
Johnk1173
Sep 9, 2017 10:14 AM
mfortkamp
Exhaust System Topics
11
Jan 4, 2013 05:06 AM
N-gin
Aug 17, 2011 04:32 PM
dog116929
Jul 17, 2008 05:27 PM
Jerry L
Aug 20, 2007 05:58 PM
