interesting phenomenon
Old Nov 30, 2011 | 12:25 PM
XjldX's Avatar
XjldX
Default interesting phenomenon
So the other night, as I go to start up the bike to head home from work, I bump the kill switch right after pushing the starter and, well, it kills the bike.
Then I start it back up and my low fuel light comes on, which I assume is because I am low on gas and parked on a bit of a hill.
As I ride home, I notice my fuel gauge makes its way up to a little under half a tank, but still the low fuel light is on.
When I get home, I turn off the bike, remove the key and give it a few seconds before turning it back on. Light still on...
So I head inside, get to the computer, head over here to the forums, look up the trouble codes to try to diagnose any issue, head back out, put the key in to check the codes and the low fuel light doesn't come back on. I check the trouble codes anyway, and nothing. Not a single one...
Is this a normal reaction on the bike's part to what I did when I started it and accidentally killed it immediately? I'm not too worried about it because it's running fine and there are no trouble codes, I just thought it was weird that it just needed to be turned off for about 5 minutes to "fix" itself. Has this ever happened to anyone else?
Cheers,
Jimmy
Old Nov 30, 2011 | 12:53 PM
Scuba10jdl's Avatar
Scuba10jdl
Using the kill switch doesn't harm most Harleys. They are wired in such a way that it is equivalent to turning off at the ignition switch.
The low fuel lights are triggered by a switch that alters its signal by the level of a float in the fuel tank. Once it comes on, it will stay on until the circuit is reset (turn the key off/on) and the float no longer indicates low fuel.
The switch itself is slow to react, so it usually takes a minute for it to recognize it is no longer on "low fuel", even if it was switched off/on again.
How Fuel Gauges Work
Old Nov 30, 2011 | 02:43 PM
rooti's Avatar
rooti
how low do you have to be on gas for it to come on? Once it showed empty, checked the computer and it said it could go another 36 miles. When I went to fill it up it had about a gallon in it. Light never came on
Old Nov 30, 2011 | 02:47 PM
axel black's Avatar
axel black
unless you trouble shoot redundent systems for a living, stop the paranoria, ride and dont worry. Thats why you own a harly any way, isnt it?
Old Nov 30, 2011 | 04:26 PM
Scuba10jdl's Avatar
Scuba10jdl
They are notoriously inaccurate. You are much better off using your trip counter and estimating when you are getting low.
Old Dec 2, 2011 | 08:19 PM
XjldX's Avatar
XjldX
I don't think it was the float in this situation.
And @axel, no paranoia, just confusion. But I figure if it's running fine and I got no trouble codes, then there is no problem... Right?! Haha!
Old Dec 2, 2011 | 10:02 PM
SURFOR Chop's Avatar
SURFOR Chop
When my fuel gauge shows around half or a little less maybe (as verified by my trip odometer reading), when I first start up, the fuel light will sometimes come on ... depending on how long I'm riding, sometimes it will shut off (usually takes about 10 or 15 minutes of riding) ...
... as the fuel gauge is 'coming up' when I'm getting ready to start my bike, it doesn't seem to register with the light switch ... which is why the light comes on ...
... when I am riding and the fuel runs down, the light ordinarily doesn't come on until the needle on the gauge drops to the red line (looks like less than a third, but more than a quarter) ... this usually occurs sometime between 110 and 13o miles on the trip odometer ...
... sometimes when the light comes on 'prematurely' (when I have more than a quarter tank left) ... I let the fuel gauge needle come up to settle above the red line ... then quickly switch the key off and back on and the light will go out ....
My bike is an '05 (so 'old technology') ... doesn't have the count down feature ....
R/
'Chop
markdavidson
2014-2024 Touring Models
Jul 18, 2016 12:10 PM
rob91326
Apr 6, 2009 05:30 PM
Thundercloud
Feb 4, 2008 10:46 AM
Larryc5079
Jan 14, 2008 12:31 PM
four5acp
May 20, 2006 08:04 PM
