new top clamp. bushings??? what gives....
so installed top clamp today. got a set of stock bushings from harley. will get poly later.
the problem is that the riders left hand side bushing wont go all the way down. I tighten it as hard as I can and it just wont go as far down as the other bushing. so there is a ton of wiggle and slop in the bars.
what would this be from
i put the bushings on a table and looked if some were different and they were not. all the same size and same lips for the seat???
for these pics i installed the bottom washer upside down so you could see how much of the bushing there is left
maybe thats the problem. there was no anti crush spacer in the middle of the bushings.
i should just buy some poly bushings that come with the metal sleeve in the middle and go from there.
sux though bars are crooked and a good amount of slop
i dont think its the bolt bottoming because the other side with the same bolt tightens right up with no problems.
and there wasnt a washer in the hole either before I installed it
maybe i should just buy these?
http://www.debrix.com/Solid-BILLET-R...28-0673-vt.htm
http://www.demonscycle.com/Handlebar...-p8249158.html
+1 to what p51 said.
If you are going to buy new ones these are my favorite, they disappear for a very clean look. Can't even see them in my sig pic.
https://www.denniskirk.com/alloy-art...prd/572178.sku
