lost fire!!!
Old Dec 15, 2011 | 09:11 AM
inkslinger73's Avatar
inkslinger73
Default lost fire!!!
I have a 86 fxr was workin excellent.Now it keep losing fire on the rear cylinder and than kicks back in and so on.tried a few new pluga same thing.I havent changed or touched anything before this issue. Any help appreciated.
Old Dec 15, 2011 | 12:13 PM
blackbear's Avatar
blackbear
It could be a bad spark plug wire or a bad coil.
Old Dec 15, 2011 | 04:02 PM
bobnehoc's Avatar
bobnehoc
It could be a bad coil as previously stated or wires. I would also vedify that you have good compression in the cylinder as well. Lastly it could be a fuel problem. Check the carb and intake manifold for leaks.....
Old Dec 15, 2011 | 05:50 PM
inkslinger73
thanks i was figuring it was a coil problem.
Old Dec 18, 2011 | 02:26 PM
inkslinger73
No coil problem as I tried a brand new one and still same.I can't seem to detect any intake leaks.Found a exhaust leak on same cylinder.compression test between 120 and 125 psi per cylinder.beats me.Has a 2-1 header and is back firing often not constantly but often.
RKRider77
Sep 23, 2017 11:27 AM
D-Bag
Engine Mechanical Topics
Jul 17, 2014 09:21 AM
errasa
May 3, 2008 07:10 AM
biker_grunt
Apr 15, 2008 09:23 PM
HokieHarley
Jun 11, 2006 12:52 AM
