Engine light flashing - Sometimes...
Old Dec 18, 2011 | 06:58 AM
BigTasty's Avatar
BigTasty
6th Gear
Default Engine light flashing - Sometimes...
The engine light on my 99 fxdwg w/tc88 flashes three times quickly and then is off for one second. It only happens intermittently. What's it trying to tell me???
Old Dec 18, 2011 | 08:33 AM
alauhog's Avatar
alauhog
I just installed a ( Back Off ) module to my taillights.
It throws the ECM in to a fault everytime I hit the brakes.
Same thing blinks 3 times then on steady for about 2 seconds then repeat.
Had it at the Harley shop Friday for Dyno and asked about it. Said it wasn't no big deal as long as I keep an eye on it to make sure no other codes come up
Old Dec 18, 2011 | 09:50 AM
dirtdobber's Avatar
dirtdobber
check the code and see what it is
Old Dec 18, 2011 | 09:53 AM
dirtdobber's Avatar
dirtdobber
this will how you how to get the engine code
http://www.youtube.com/watch?v=RTy_JKI9cQ0
Old Dec 18, 2011 | 02:51 PM
BigTasty's Avatar
BigTasty
6th Gear
When I hold the odometer button and turn on the ignition the display reads: d015Et. If I press the button again I see d02CLR and each time I push the 2 changes to 3, 4, 5 on up to 10. Push again and I see CAL 09 then d01CLR and so on. Suggestions???
Kyle C Kirk
Nov 9, 2015 02:13 PM
chizman
May 15, 2011 04:35 PM
scooby doo
May 18, 2009 07:59 PM
gatorwalt
Jul 24, 2008 10:26 AM
20NightTrain03
Jul 6, 2006 12:00 AM
