07 6 speed Dyna rpms at speed
Old Dec 10, 2006 | 07:26 PM
RonnR's Avatar
RonnR
Default RE: 07 6 speed Dyna rpms at speed
Ive posted this before,, But for those who havent seen it....This is an excel chart that allows you to enter your tire size/ then any rpm/ and it will calculate the speed in any of the 6 gears of the 06' dyna.. Pretty sure the '07 gear ratios are the same, if however their not the same, you could input correct ratios if you had them. Really pretty handy,,,But I havent been able to upload to the forum. The forum will only allow pics..
If any one is interested E-me and I'll be glad to sent it to ya...Its pretty handy........
Ronn
Old Dec 10, 2006 | 08:03 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Has anyone suggested installing a tachometer? The lowrider has one stock.......you get hooked on it right away.
Old Dec 11, 2006 | 11:49 AM
jimw411's Avatar
jimw411
ORIGINAL: dlongo8241
I must be a retard becuase I can't figure this out, I tried the first caculator and I get 11500 rpms at 70 mph?
Thats the right RPM for a GSX-R in 3rd gear at 70MPH.
If harley actually made a V-twin spin that RPM the Japs would get scared.
Old Dec 12, 2006 | 11:20 AM
dlongo8241's Avatar
dlongo8241
that would be great if you can sent it to me I would appreciate it. dlongo8241@yahoo.com
Old Dec 12, 2006 | 11:28 AM
SPECIAL ED's Avatar
SPECIAL ED
[quote]Thats the right RPM for a GSX-R in 3rd gear at 70MPH.
If harley actually made a V-twin spin that RPM the Japs would get scared. [quote]
I don't know about that, that's about redline on my 2000 SV650.
Old Dec 12, 2006 | 02:39 PM
murphdog's Avatar
murphdog
ORIGINAL: RonnR
Ronn
RonnR, the ratios are different for '07. They changed the rear sprocket to a 66 tooth from a 70 tooth. I made a spreadsheet that calculates speed in gears for 5 speeds, '06 Dyna 6 speeds and '07 6 speeds at an entered rpm if you want it. It may even be a previous version of the one you have. I tried to email it to you, but the forum email doesn't seem to allow attachments.
PM me your email address and I'll send it if you want it.
Old Dec 12, 2006 | 05:29 PM
darkkevin's Avatar
darkkevin
ORIGINAL: DougsDyna
thanks for you responses 2700 at 75 you can drive 24/7 at that rpm without hurting a thing wow thats nothing engines hardley moving.
Go figure............ Mine doesn't seem to mind steady rinding in 5th or 6th at speeds over 100 mph. 6th just cruising at 120.
DougJ
are you seriously telling me you are perfectly comfortable cruising 75-85mph in FOURTH GEAR?????
Old Dec 12, 2006 | 11:50 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: darkkevin
ORIGINAL: DougsDyna
DougJ
Yes
albrown
May 24, 2018 12:28 PM
Tangle Eye
24
May 24, 2013 02:57 PM
rodeking
Jul 24, 2009 04:03 PM
dynalowride
Jun 13, 2007 11:18 PM
priceamp
Oct 23, 2006 06:16 PM
