Wheel swap
Old Jan 6, 2012 | 01:18 AM
nexeradg's Avatar
nexeradg
Default Wheel swap
A buddy of mine just bought an 09' Superglide. He's been wanting to get spoke wheels and I have been wanting mag wheels (11' Streetbob). Would this be able to work? Secondly, I've noticed his rotor setup is different as well. Are there any benefits/drawbacks to the 1 piece vs. the 2 piece floating rotor on my Bob?
Old Jan 6, 2012 | 04:35 AM
crimson13's Avatar
crimson13
Don't know of any draw backs on the rotors. I am wanting to do the same thing go to mags from spokes,from what I read on here it is a direct swap except for the rotor on the front the rear is the same.
Old Jan 6, 2012 | 09:27 AM
nexeradg's Avatar
nexeradg
So the Superglide rotor will fit in the Streetbob caliper without any clearance issues?
Old Jan 6, 2012 | 09:48 AM
Gringoloco13's Avatar
Gringoloco13
As long as the rotor is the same dimensions as your bob, width/overall size, etc. The only thing that won't fit is your wire wheel rotor on a mag wheel and vice versa, reason being the bolt holes are differant. In other words if you tried to use a stock street bob wire wheel rotor and bolt it on a mag wheel the holes won't line up. So keep this in mind when you order aftermarket rotors or new stock ones, if you put on the mags and buy rotors to fit a stock bob wire wheel you will see what I am saying. So you will have to order rotors for the superglide model, if that makes sense.
Old Jan 6, 2012 | 10:22 AM
PHA-Q's Avatar
PHA-Q
Leave the rotors on the wheels they came with and its a direct swap...
Old Jan 6, 2012 | 01:25 PM
nexeradg's Avatar
nexeradg
Excellent. Thats exactly what I needed to know. Thanks!
J-Dog
Jun 1, 2014 10:54 AM
WhereduGo?
May 24, 2013 03:07 PM
speedydog5
Mar 26, 2012 12:11 PM
bergys
Mar 8, 2010 02:12 PM
miketedesco
Dec 8, 2009 07:55 AM
