Who's got floor boards?
Old Jan 26, 2012 | 11:57 AM
SPECIAL ED's Avatar
SPECIAL ED
Default Who's got floor boards?
I have a set of floor boards like these http://www.ebay.com/itm/ADJUSTABLE-D...sories&vxp=mtr laying around in my shed I'm thinking of trying em out.I'm interested in seeing what other floor board options are available for Dynas.Most of the generic/cheap adjustable ones are saying they're not recommended for mid controls.Why not?
Old Jan 26, 2012 | 03:06 PM
bikerlaw's Avatar
bikerlaw
I have the same brand in the half moon flavor. My guess with the mid controls is that due to the size of the boards, you just would not be able to operate the controls effectively. There may be a way to set them up with mids, but looking at mine I just can't see them working. If you did get them on they would probably need to be be so low they would be very restrictive to the bikes ability to corner as well. They really are meant for bikes with forwards. Just my observations of course. That being said, I have noticed that people can be pretty darn creative on this forum, so maybe others have pulled it off???
___________________________________
Old Jan 26, 2012 | 05:39 PM
Harley Tim's Avatar
Harley Tim
I have footboards for a '12 FLD Switchback on my '06 FXDi Superglide. works good....looks like the've belonged there all along. It's about a $ 400.00 to $ 450.00 mod.
If you're intrested, I'll post some pics and a list of PNs, prices, and notes FYI.
There are also a few here on the Forums that use the footboards for a FXDP (police).
Just do a search for "floorboards on a Dyna" here. There's plenty of info here on that subject.
Hope this helps.
Best wishes....Tim(HT)
Old Jan 26, 2012 | 05:50 PM
AFMM3's Avatar
AFMM3
Some of us have actually adapted Softail floorboards to fit. The FXDP are very expensive (about $500 used on eBay), Wyatt aftermarket copy of FXDP is about $400 and better suited for shorter legs. FLD system is made for the Dyna and just became available this year and as stated runs about $450 and a perfect bolt on.
I have about $150 into my FLSTF floorboards but require you to make an adapter, there are none in the aftermarket.
Old Jan 26, 2012 | 07:27 PM
SPECIAL ED's Avatar
SPECIAL ED
Do they sell the FLD floorboard system as a kit or do you have to buy all the parts separately?
Old Jan 27, 2012 | 06:40 AM
Harley Tim's Avatar
Harley Tim
At the time I did mine, my parts guy had just recieved "shop copies" of the parts book for the FLD, the parts were purchased separately. I doubt that has changed. The list I offered previously, is compiled straight out of the FLD parts manual and my reciepts. My parts guy helped me research The info I provide with my notes. And I've got a few afterthoughts about it.
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the <A href="https://www.hdforums.com/forum/" target=_blank itxtNodeId="199" itxtHarvested="0">brake</A itxtNodeId="197" itxtHarvested="0">:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For ’96-’00 models
34639-01 RETAINER $ UNK (See note #4) For ’01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the ’12 HD custom book (I’m not real big on chrome) and my parts guy gave me a set of stock “take off” standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
__________________
Jersey Drew
Jun 26, 2019 09:59 AM
cmc#5
Aug 7, 2016 10:45 AM
Whtwolf14
Sep 14, 2015 07:49 AM
PoPo75
Sep 23, 2012 10:49 PM
Mike Horrell
Jan 19, 2010 08:27 PM
