Need some help from the more experienced
Old Feb 2, 2012 | 06:56 PM
SPERO56's Avatar
SPERO56
Default Need some help from the more experienced
I have a 2010 Street Bob and with Screaming Eagle spark plug leads. Ditched the plastic clip that separate the leads as the SE versions are too fat.
Now I can't find anything to fit and have had to fashion something out of a car part - which works but aint pretty.
I went to the local HD dealer and they first told me they didn't know what I was talking about; then they said HD do not offer this part with SE leads. So guys any idea where I can find something that will work?. Many thanks.
Old Feb 2, 2012 | 07:05 PM
dag5984's Avatar
dag5984
black zip tie....not too tight
Old Feb 2, 2012 | 07:06 PM
rooti's Avatar
rooti
why don't you carve out the plastic clips a bit and reuse them?
Old Feb 2, 2012 | 07:10 PM
SPERO56's Avatar
SPERO56
Dag - that might be my best solution yet.
Rooti - I tried that and it's a piece of crap to cut as there's next to nothing to work with but thanks for responding.
Just wondered if anyone else has seen anything that would look neat otherwise I'll go the zip-tie route.
Old Feb 2, 2012 | 07:35 PM
Lefty79's Avatar
Lefty79
If there is enough meat around the existing cut-outs just drill them out. I did this on a car once. I just held the clip with some pliers and slowly pushed the drill bit thru. Hope that helps.
Old Feb 2, 2012 | 07:38 PM
Austin Dave's Avatar
Austin Dave
Ran into same problem. I bought a 4-wire keeper, cut it down to 2-wire and used Dremel to enlarge. If you mess up the first try, you have a second to 'perfect' your technique. Look for the Help brand at local auto parts store for the keepers. Since I did that I've seen the SE 10mm wire sets WITH keepers online. Don't recall where tho. 10mm keepers must be made 'somewhere' and why a H-D dealer doesn't know this....?
bobnehoc's Avatar
bobnehoc
Did you check with JP Cycles or Dennis Kirk or Drag Specialties? Perhaps one of them would have a wire loom that is the right size.....
Old Feb 3, 2012 | 06:39 AM
Harley Tim's Avatar
Harley Tim
Try a "zip" tie, with a short piece of automotive vacume hose. Slide the tie thru the hose, around one wire, then back thru the hose, and around the other wire, then fasten the end. works good for me.
Hope this helps
Best wishes....Tim(HT)
Old Feb 3, 2012 | 06:47 AM
nkauf21's Avatar
nkauf21
Relocate your coil!
Old Feb 3, 2012 | 11:07 PM
ackman1968's Avatar
ackman1968
+2 Zip ties.
http://foureyedpride.com/joom/index....-art&Itemid=42
Port Dawg
Aug 6, 2011 10:09 PM
Bdhouse61
Apr 30, 2011 07:48 AM
silentfeet
Mar 21, 2009 07:57 PM
ontcanuck
May 7, 2007 08:37 PM
KBES BAGGER
May 3, 2006 10:42 PM
