Switchback FLD forward control "extensions" please HELP
I saw one guy selling some modified boards at the long beach swap meet where he removed the brackets and moved them back, rewelded, and that gave about 1.5" more forward. Moving them forward is only part of the solution. they also need to move out so you don't have your boot stuck under the brake pad. I know you know what i mean on that.
I bought some kuryakyn flip blades that don't work for me but might work for you. For me, they extend me out too much and locks my knees. they might work for you, for now, until they come out with extensions and I'd sell them.
PM me if interested.
Another thing that REALLY helped was changing out to a mustang solo w/backrest, and pillion (pics in my albums). That moved me back about an inch or so and feels great.
I have been looking for floorboard extenders since you first posted. No joy. Today, I saw the new 2012 HD Accessory Book and no floorboard extenders there. In fact, sadly there were only a few new items available for the SB. HD did come out with mini floorboards which could also be used as highway pegs. I am not sure that will help you. I have not been able to get my welder to meet with me as his restaurant business is taking off. I hope to see him after the Super Bowl but without the bike and you sitting on it he may not take the project on. We'll see.
The front board mount connects to the frame at the point where (and in the same manner as) forward controls mount ...
My concept is to install a forward control extension kit to the front board mount ... something like this ...
(Product 89/209, Model D41230 on Fog Hollow web site listing for $75 and currently discounted to $63.75)
There are 3-inch and 2-inch kits available ... a popular 3-inch extension kit is made by Kuryakyn ...
For the rear mount, the owner would need to engage a machine shop to make a corresponding extension plate for the rear mount ...
The key consideration would be to ensure the special construction rear mount support extension plate be made of sturdy enough stock (ensure adequate thickness and hardness) to support the board assembly to the same load-bearing (weight) and stiffness standards as the stock setup ...
This system would move both the front and rear footboard brackets forward by approximately 2 or 3 inches and replace the brake rod and shifter rod with longer ones (I think the shifter rod might not have to be replaced as the lever could just be rotated to the rear to compensate) ... this would move the entire board assembly forward by the desired amount ...
First one to fabricate the rear mount, provide details on which forward extension kit used, post detail drawing and source of supply for others who want to follow suit ... the fabricator gets additional business and a greater number of FLD Switchback owners have access to extension kits ...
An example of something I did where I engaged a machine shop to fabricate special construction adapter was for my rear fender adapter struts ... turned out great ...
Yes after-marketeers, where are you on this?
Nice post, chop
