2003 fxdx Help with new Bars
Old Feb 13, 2012 | 05:10 AM
03fxdx's Avatar
03fxdx
3rd Gear
Default 2003 fxdx Help with new Bars
hey, i want to swap my current stock bars on my 2003 fxdx, to 10" tbars, was wondering if anyone on here has done the swap before and tell me what ill need so i can order everything at once? thanks
Old Feb 13, 2012 | 05:33 AM
Good_Apollo's Avatar
Good_Apollo
I did, but the previous owner had already put some big ugly buck horns on it, so I didn't need new cables, mine were already long enough, of course mine are only 9" rise. Do yourself a favor and get a new wiring harness with matching wires and pull it through the bars before you start the install, that is the hard part. Then you can just solder the controls on and tie it into the main harness at the bottom and you are done.
Old Feb 13, 2012 | 07:20 AM
JohnC FXDX's Avatar
JohnC FXDX
Definitely get matching wires. I'm in the process of changing my bars, sorry not going to 10" though, but the old ones were about a 7" T bar. Supposedly they were installed and wired by a local HD dealer. The wires were spliced with other extensions between and none of the colors match. Big pain in the rear.
Old Feb 13, 2012 | 10:36 AM
shiftace's Avatar
shiftace
Everything will fit with just a little rerouting and wire tugging. Brake line is the only part that sometimes gives people fits. It can be straightened enough to give the length needed, but it's not a bad idea to get a longer one made. My controls are 13.5in off the trees with only a 3in longer brake line. Everything else is stock
Old Feb 13, 2012 | 03:10 PM
03fxdx's Avatar
03fxdx
3rd Gear
Do you remember where you got 9" tbars?
Old Feb 13, 2012 | 06:36 PM
parts eeter's Avatar
parts eeter
Good Apollo got his from Westcoast I believe.
Old Feb 13, 2012 | 06:47 PM
Good_Apollo
Yeah, I got them from westcoast. They will make any size you want, the 9" cost me the same as the 10", I just had a 2 week wait while they made them.
Old Feb 13, 2012 | 07:05 PM
03fxdx's Avatar
03fxdx
3rd Gear
thanks apollo and everyone else i really appreciate it
Old May 5, 2012 | 03:56 PM
jslum's Avatar
jslum
anyone have a problem with the speedo wires? mine are tapped out and super tight. Does harley make an extension?
Old May 5, 2012 | 05:55 PM
DynaGlider27's Avatar
DynaGlider27
Default bars
I went to 13 inch straight rise bars and they are great. The only thing I had to change was the clutch cable, and of course extend the wires. good luck.
