Bike Lift
Old Dec 17, 2006 | 04:54 PM
warren888's Avatar
warren888
Account Suspended
Default Bike Lift
Just bought a decent bike lift on sale from Cycle Gear for $59 (couldn't believe it).
However, I'm not sure if I can lift my '06 lowrider directly - the engine seems to protrude a little below the frame, and there is a welded piece on one side of the frame.
Does anyone know if you need some kind of supports to lift the '06 lowrider?
Thanks..
Old Dec 17, 2006 | 05:06 PM
StreetSalvation's Avatar
StreetSalvation
Default RE: Bike Lift
This one has been tossed around the forum. If I remember correctly, to properly lift your bike on a fame type jack, you either have to make supports or buy then from HD for under $30. Of course then strapping it down. I hope this helps.
Merry Christmas!
Street
Old Dec 17, 2006 | 05:12 PM
Bob's Avatar
Bob
Here's what's needed.
Twin Cam - Equipped Dyna™ Model Motorcycle Service Lift Adapter Kit
Provides the necessary clearance of the oil tank that allows the Motorcycle Service Lift
P/N 94653-98 to be used on '99-later Dyna™ models equipped with the Twin Cam engine.
98965-99
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
MSRP US $21.95
[IMG]local://upfiles/16850/EDE9EDEFD50C4F12A230069692255656.jpg[/IMG]
Old Dec 17, 2006 | 11:40 PM
DGlide04's Avatar
DGlide04
06 is right, the best coin you'll spend on a maintenance item, makes getting the bike up in the air a breeze. Just make sure that you have enough clearance under the bike before you try to slide the lift under the frame, on most lifts it's pretty tight, but easily solved by riding the bike up on a 2x6 to get the back wheel off the floor an inch or two. Once that's done, there should be enough clearance to get the lift and adapters in place.
Old Dec 18, 2006 | 12:12 AM
warren888's Avatar
warren888
Account Suspended
Thanks everyone ... much appreciated.
oh well... how could I possibly fathom that I could just buy something for a moco product without having to buy another something to make the first something work [&:]. They have a good gig going don't they!!
Old Jun 26, 2007 | 05:57 PM
hounddog's Avatar
hounddog
So then you block up the hole left side and then just in front of the fin on the right and just jack it up??? i was concerned about the weight on that fine but i guess if you block the other areas to get it level then yer alright. that silly fin gaurd is a pain but i guess needed to protect the trans and i suppose its lower than the frame to get a better seat height. if this is whats needed than im just going to make a few blocks the same thickness as that fin. thanks guys
Old Jun 26, 2007 | 08:53 PM
Wide Glide 05's Avatar
Wide Glide 05
Got the red jack from Sears, had it up on the lift most of the winter, in the house, moved it around a few times, no straps, no problems. I made spacers out of wood for the rear left to offset the guard welded on the rear right and a piece on each side in the front. Got the short shocks on it so it sits lower. Block of wood under each tire and one under the jiffy stand lets the jack go right under, no problems. Easier than jacking a 400,000 lb. C-5 Galaxy and THAT is easy!!!!
Bluesrider.df
May 26, 2018 09:41 PM
PKellyMc
Nov 21, 2008 03:41 AM
brubo
Jun 25, 2007 10:38 PM
niskyne
May 26, 2007 07:56 PM
cajunman831
Aug 12, 2006 12:13 PM
