Conversion kits
Old Feb 18, 2012 | 08:24 AM
ice6971's Avatar
ice6971
4th Gear
Default Conversion kits
Got a question for you guys, I have a 2009 FXD, was wanting to know if there is a way to eliminate the speedometer on the handlebars. Riding it for the past couple of years, I would like to put it down lower, clear up some space on my narrow grip apes. Thanks for the help
Old Feb 18, 2012 | 10:23 AM
Robtarra39's Avatar
Robtarra39
You have several options, you could get a wideglide tank and switch it over to the tank, that is what i did, or get a sportster custom riser set up and moves it behind the bars instead of up on top,, if you have high risers then they make a speedo clamp that attaches to the tall risers. I have attached a pic of the sportster riser set up used on the custom models, these can be bought used on Ebay, i have seen these used on Dynas and these risers also come straight or pull back version
Attached Thumbnails Conversion kits-0406_02z-2004_harley_davidson_xl1200c_sportster-speedometer_view.jpg
Old Feb 19, 2012 | 08:47 AM
ice6971's Avatar
ice6971
4th Gear
Thanks Robtarra, switching tanks is really not an option for me right now because I just sent mine off to be painted. So I will check into the other
Old Feb 19, 2012 | 10:15 AM
Robbie13's Avatar
Robbie13
LOSER
Forum member Skinless went with a small Dakota Digital mounted between bars and tank. It turned out well.
Old Feb 19, 2012 | 12:53 PM
DCLXVI's Avatar
DCLXVI
I forget now who makes it but there is a mount that bolts to the left fork leg that works pretty well. It moves the speedo and the idiot lights as well.
Old Feb 19, 2012 | 06:17 PM
armybrat02's Avatar
armybrat02
Is this the RSD part? I saw one on a Sportster 48 that was at my Dealer for a raffel.
Old Feb 19, 2012 | 09:37 PM
mracer's Avatar
mracer
Joker makes a speedo relocate for FXD's-looks cool mounted down below bars on left side. I think there are some pictures here- search this site.
kyleohioguy
Jul 29, 2014 05:57 PM
K9BO
May 31, 2012 10:03 PM
toemoss
Apr 27, 2007 10:56 AM
saltlick
Feb 3, 2007 08:18 PM
Lightngsvt
Oct 25, 2006 09:50 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
