Polishing aluminum??
Old Feb 20, 2012 | 07:41 PM
ynots's Avatar
ynots
Ive had great luck with Never Dull
also try Mothers Aluminum polish or Brasso.
Id only use something like steel wool or fine sandpaper as a last resort
Old Feb 20, 2012 | 07:53 PM
Uncle Larry's Avatar
Uncle Larry
http://www.competitionchemicals.com/simichrome
I used this ( Simichrome ) for many years and always had great success with it .... there are a number of good aluminum polishes on the market ... pick one .... and after you have used it a few times you too will say " This is the best stuff I ever used on Aluminum "
Old Feb 20, 2012 | 08:14 PM
nathanw's Avatar
nathanw
I've used this stuff on every aluminum object I've ever had and my father has used it forever too. Excellent stuff.
Old Feb 20, 2012 | 08:21 PM
Slim_B_Kool's Avatar
Slim_B_Kool
I use meguirer's all metal polish and a good clean polishing cloth brings out a mirror shine and not alot of rubbing.
Old Feb 20, 2012 | 08:23 PM
Romark's Avatar
Romark
Very fine sand paper or steel wool will do the same as polish. They both remove metal to get past the etched corrosion. Just depends how much you want to rub. Your results will be great and low maintenance once you get it right
Old Feb 20, 2012 | 08:40 PM
blacknsilver's Avatar
blacknsilver
Originally Posted by PigInaBlanket
Yea the Mothers power ball works great. I used it on the wheels of my wife's car which had not been polished in a few years and they came out shiny as hell.
That Power ball is a little big for the uses on my bike (I only have the triple trees to polish) so I just use Mothers billet polish on a rag for that and if I keep it up it's pretty easy.
I used mother powerball also with Mothers Mag and Aluminum polish on my fatbob wheels and turned out great.
Before:
After:
Old Feb 20, 2012 | 08:43 PM
pushcart's Avatar
pushcart
This may sound crazy, but I've used wadded up aluminum foil dull side out and white vinegar.
Old Feb 20, 2012 | 08:45 PM
kk883's Avatar
kk883
2nd Gear
i use semichrome too. stuff is awesome.
Old Feb 20, 2012 | 10:12 PM
roneil's Avatar
roneil
Before:
After:
i need to do this to my wheels too. great job.
Old Feb 21, 2012 | 06:21 AM
stichback's Avatar
stichback
I've used jewelers rouge on a buffing wheel for really bad stains with good results. Comes in 3 grits. I used the darkest one. GL
