Your cage has either a (map) Manifold absolute presser sensor, or a (maf) Mass air flow sensor, These tell the computer how much air the engine is ingesting, so your cage is better at adapting to changes in exhaust and air cleaner changes.
Harley EFI lacks these sensors, so the computer is set with very narrow parameters, when you make a change, in a/c and exhaust, the airflow into the engine changes, and exceeds the set parameters, therfore they need to be changed, to accommodate the new airflow.
Umm, actually Harleys do have MAP sensors, along with several others.
Foxster is right. H-D Stage 1 download has slightly different timing baseline (another learned behaviour of your ECM) and bumps up the RPM limiter, NO FUEL ADDED per California Air Resources Board evaluation report.
Download the instructions for TTS Master Tune. Read it, understand it and you will never have to guess again. Even they admit in the instructions that a tuner is not necessary for normal operation but is desirable to get as close to perfect a Harley motor can be.
07 up ECM's with o2 sensors CAN compensate for the changes you made, but it will only get you back to stock AFR settings. which most believe is a bit lean, but it is safe. If you get stuck in lots of traffic, a tuner is a damn good idea so you can lower the AFR to help her run a little cooler.
In laymen terms....
Narrow band o2 sensors means they can only get you back to a preset AFR, Wide Band sensors like I have in my ThunderMax allow you to make bigger changes and lower the AFR, I run around 13.5 which makes a huge difference in heat produced.
What about XIED's? Would that drop the ratio low enough, or is it a $100 gamble? From what I have read, if you get it down to 13.8 by "tricking" the computer it would be a sufficient adjustment. Sorry if this is a dead horse. I'm new to Harley- recovering Ducati addict.
I have never tried them, but, from all I have heard and read, yes they do work.
My only point would be that they do not allow optimum performance to be gained. I tried other tuners first, FuelPak, PC III, before buying a ThunderMax, I wish I had done it right in the first place instead of spending money on what were in the end, half measures.
It will lower your AFR to 13.8, Id recommend it over the HD stage 1 download
Originally Posted by razors edge
can anybody throw out a ballpark on cost to flash the ecm?
In regards to the OP's request for info concerning whether he was good to go, would it also depend on if a MAF was present? I found a sensor connection plugged into the back of the air cleaner (FXDC) base plate. No active connection, does something get added to this to allow ECUs to accomodate higher air intake flow?
No, I believe the connection you are referring to is for International models only to meet some EPA type requirement there.
