Installing new bars this weekend
Old Mar 1, 2012 | 12:19 PM
JRK5892's Avatar
JRK5892
if you are going to do it, do it right run the wires inside the bars looks 100000% cleaner
Old Mar 1, 2012 | 12:20 PM
128auto's Avatar
128auto
Do you have a choice? Do you mean can you wire it external? It's up to you, I would do internal wiring while you are there, it looks much cleaner. One trick I've learned is using beads chain to guide the wires in, it's easy.
Originally Posted by phat413
Do I have a choice on the internal wireing?
Old Mar 1, 2012 | 12:32 PM
pontiac69's Avatar
pontiac69
also when pulling the wires though the bars stagger them so your not pulling a big lump through. its much easier if you stagger the pins. like others have said we are all here to help. just work patiently and take your time. also make sure you make a good drawing of your connectors so its easier to reasemble.
Old Mar 1, 2012 | 12:38 PM
Basic's Avatar
Basic
I've done a few sets of bars internally wired and it's not a hard job at all. A manual is key as it provides processes for removing the pins from the plugs, running cables, etc. I also always take step by step pics of the wiring so I can easily work backward when putting the pins back in the plugs.
Old Mar 1, 2012 | 01:25 PM
XjldX's Avatar
XjldX
I wish I had drilled my bars for internal when I swapped bars, but like an idiot, I figured swapping all my cables for going from buck horns to 12" was more than enough for my noobie brain to process. In reality, I would've been better off just doing it all at once.
Like others have said though: go slow, it's not a race. Take your time and do it right and you won't regret it.
Old Mar 1, 2012 | 01:37 PM
Buckinfitch's Avatar
Buckinfitch
I got a 11 street bob and I got some wild 1 chubby 12".
So what do you think the level of difficulty will be?
cover your tank and fender with blankets to avoid the drop knicks
Old Mar 1, 2012 | 02:32 PM
Punchsmack's Avatar
Punchsmack
I've been worried about the same thing. I know the bars I want, but I don't know which cables to buy.
And for the installation, I don't have a garage to do the work (in a downtown condo parking space). Maybe I'll have to hit you up Joe. Do you think we could get the work done in one trip to your house/business?
Old Mar 1, 2012 | 02:56 PM
bswearingen's Avatar
bswearingen
yep, not hard. No doubt you can do it
Old Mar 1, 2012 | 07:26 PM
biketroll's Avatar
biketroll
The manual is a big help.
Old Mar 1, 2012 | 08:16 PM
pontiac69's Avatar
pontiac69
i know alot of people talk about a manual. well i bought one when i bought my bike. i have to say i didnt need it at all for a bar swap. even the connectors was easy since i just wrote down a detailed diagram when i was taking it apart.
