I change my motor oil at 2500 miles. Every 3rd time I change the primary and tranny too. So that puts it at around 7500 for the primary and tranny. As for the belt, doing it by eye is fine. No need for some special HD tool.
Change the other fluids too, it's easy and you are already doing the oil anyway and if it's your first 5000 miles then it's due. HD Formula+ isn't expensive, I use it in both tran and primary works great, after change with every third oil change. Amsoil in the motor for me.
I do all three fluids every 5k. I did get the belt adjustment tool since it should be measured with the bike sitting on the back tire, not jacked up. (Technically should have the rider's weight on the bike as well) At my old age, crawling down on the garage floor is challenging enough. I find the tool makes checking deflection easier. And as I recall it's not expensive.
