2010 wide glide front fender mounting?
Old Mar 12, 2012 | 02:56 PM
LCHBuilders's Avatar
LCHBuilders
Default 2010 wide glide front fender mounting?
Hey guys, Ive got an easy one for you. When i bought my bike, the previous owner had removed the front fender. I just bought a fender from Russ Wernimont, and im wondering how the fender mounts to the fork legs? A special bracket or spacers? There are holes on the fender but when its centered there is an inch and five eigths gap on each side. Pictures of a mounted stock fender would be awesome. Thanks guys!
Old Mar 12, 2012 | 03:15 PM
pontiac69's Avatar
pontiac69
the brackets that come off a stock fender reach the forks.
Old Mar 12, 2012 | 03:23 PM
ssee's Avatar
ssee
I snapped these with my phone so the quality might not be the greatest but I hope they help.
Old Mar 12, 2012 | 05:16 PM
LCHBuilders
So by the looks of it, the mounting bracket is formed right into the fender. Now the question is do i make a bracket or cut some spacers out of tube stock. Nothings ever easy i tell ya!
Old Mar 12, 2012 | 05:24 PM
Reaper_ggy's Avatar
Reaper_ggy
or you can just buy spacers if you dont want to repaint
Old Mar 12, 2012 | 05:25 PM
Reaper_ggy's Avatar
Reaper_ggy
http://www.ebay.ca/sch/i.html?_from=...All-Categories
Old Mar 12, 2012 | 05:37 PM
LCHBuilders
Well that makes it easy!! Appreciate the info Reaper! At least I know now that my spacer idea will work. I may just make them, plan on riding this weekend and I'm not sure if those would make it to my door in time.
Old Mar 12, 2012 | 05:42 PM
Reaper_ggy's Avatar
Reaper_ggy
Glad to help !
Old Oct 10, 2012 | 08:53 AM
WG2011's Avatar
WG2011
Looking at getting this fender you speak of do you have any pics with it installed?
Old Feb 24, 2013 | 01:38 PM
sgarrett36's Avatar
sgarrett36
Stage I
Russ Wernimont Designs makes a front fender specific to the Dyna Wide Glide front end for 2006 and beyond, as everything changed on the '06 model. Therefore, the fender mounting is different, so either a fender specific to this model (such as the RWD-50086) is required, or custom spacers and modification to an aftermarket fender. As the Dyna Wide glide fender mounts on the lower fork legs are positioned vertically - vs. horizontal like on most Softtail and custom applications, you need to ensure that the fender can accommodate the unique vertical mounting application, and that any spacers you get (along with the fender) will accommodate the 1" on center mounting holes in the lower forks. Most aftermarket spacers are for the typical 2 to 2.5" on center hole spacing for the more common fork lower leg mountings. NOTE: The RWD-50086 fender comes with the appropriate 2006 and above Dyna Wide Glide fender mounting spacers. J&P, Dennis Kirk, Wanaryd and slickcustoms.com all sell this part, but most do not carry it in stock so you may encounter a backorder situation. It runs $250-$280. This is a bolt-on kit, but you may be able to find a custom part that requires custom fitment (hole drilling) and custom spacers for a little cheaper.
mattVA
Nov 8, 2012 06:37 AM
moody31699
Feb 23, 2012 09:54 PM
blackedout08
Nov 16, 2009 01:33 PM
Zinje
May 10, 2009 12:32 AM
fryeca
Dec 9, 2007 11:10 AM
