Fender question
Old Feb 22, 2012 | 08:26 PM
moody31699's Avatar
moody31699
Post Fender question
I have just put Arlen ness hot legs on my 09 sreet glide and I have on order a Klock werks wrapper fender, my question is with the new forks and different fender I cannot seem to figure out how to make them mount up. The ness legs are almost like stock Harley legs and the new fender doesn't have the same mounts it is rivet less with out the notch in the fender, can some one give me an idea about how to make it work with out hacking it up thanks D
Old Feb 22, 2012 | 09:25 PM
ICIBUY's Avatar
ICIBUY
Did the fender not come with any brackets? Might get more help on this if you posted a picture or 2...
Old Feb 22, 2012 | 09:31 PM
moody31699's Avatar
moody31699
The fender is per drilled and uses Klock werks fender spacers that are half moon cut to match the fork tube the problem is that the bracket on the fork tube is really meant for a stock type fender and I can't give pics I don't have the fender yet
Old Feb 22, 2012 | 10:32 PM
ICIBUY's Avatar
ICIBUY
My FBI brackets mount to the fork tubes just like the stock ones do. Sorry not much help, maybe call the vendor that you purchased it from and make sure you received the correct brackets for that fender.
Old Feb 22, 2012 | 10:36 PM
moody31699's Avatar
moody31699
I spoke to both makers and they said I would have to customize it myself and I'm not looking forward to that
Old Feb 23, 2012 | 09:36 AM
Thedink's Avatar
Thedink
Its not hard, had to do it even with a ness fender. The block sticks out quite a bit on the hot legs. Do measureing from bolt holes, build a cardboard template of what needs to be cut out in reference to the mount hkles, once template is perfect, trace the notch to fender. Cut cut, sand smooth and send to paint.
Old Feb 23, 2012 | 09:46 AM
ICIBUY's Avatar
ICIBUY
Ugg... I dont blame you! I'm glad I bought the FBI in that case. Measure 3 times drill once I guess... good luck.
Old Feb 23, 2012 | 10:43 AM
hougz79's Avatar
hougz79
Wow. Crazy they don't make them more user friendly. Glad I did the Black HD legs. Now I just have to get a flush mount axle and right leg cap.
Old Feb 23, 2012 | 09:54 PM
moody31699's Avatar
moody31699
Yeah I wish it was more user friendly but I was on the phone with ness today and they will machine a block spacer for me and the fender comes per drilled so hope fully all will line up I will have to see thanks for the replys D
cowbode
Apr 16, 2015 04:10 PM
nefdez
Jan 18, 2013 01:52 AM
chipdavey
Jan 24, 2010 10:32 PM
jslamerman
Aug 23, 2009 12:08 AM
pelliott6
Jun 20, 2009 08:24 AM
