air cleaner cover doesn't fit need help
Old Mar 13, 2012 | 10:52 AM
pontiac69's Avatar
pontiac69
Originally Posted by HDHornet
Did you install the washer that comes with it? Very important or it won't fit.
i just thoght about that. if i remember correct you put a washer between the air filter and the star.
Old Mar 13, 2012 | 02:18 PM
HDHornet's Avatar
HDHornet
Yes you need the washer, it goes between the star shaped mounting bracket and the air filter, mine came with one. Just go out and buy one, I woulldn't be bending the mounting bracket.
Old Mar 13, 2012 | 08:19 PM
salebrity's Avatar
salebrity
The washer sounds like the best solution. Any particular thickness? Or just stick a couple in there til the screws catch?
Old Mar 13, 2012 | 09:24 PM
pontiac69's Avatar
pontiac69
you only need one standard washer.
Old Mar 13, 2012 | 11:00 PM
ynots's Avatar
ynots
I put a 1/8" spacer between the element and bracket so it will make the star stick out farther. I used a nylon spacer
Old Mar 14, 2012 | 06:40 AM
salebrity's Avatar
salebrity
found the washer. mounted right up. thanks everyone!
themizz
Feb 22, 2014 04:34 PM
digital
Jan 12, 2012 02:44 AM
Imagepix
Exhaust System Topics
May 21, 2011 03:29 PM
livelikeyourdying
Aug 16, 2009 12:05 PM
txoval
Mar 7, 2009 01:27 PM
