7" headlight
Old Mar 13, 2012 | 10:08 PM
cmancini26's Avatar
cmancini26
Default 7" headlight
Ok long story short have 07 fxd put 7" headlight on bought a aftermarket lens put trim on and lens wobbles in housing After trim is installed any ideas on how to fix this also I'm using the screw from original housing if that matters
Old Mar 13, 2012 | 10:50 PM
ian03xl's Avatar
ian03xl
How does it compare to the lens that came with the light?
Old Mar 13, 2012 | 10:55 PM
cmancini26's Avatar
cmancini26
Didn't have one. But I'm looking at pictures and see the trim on a lot of them goes like the original trim did and the bucket and trim I have have tabs on each of them to tighten down of that helps
Old Mar 13, 2012 | 11:23 PM
xantasm's Avatar
xantasm
Use something like a strip of coated wire like and O ring and that will solve it. I had one that was that way and that did it. You can also just wrap the outer edge of the lens in electrical tape until its thick enough to be snug in the housing. Pretty much anything creative that won't dissolve in water or corrode easy will work.
Old Mar 14, 2012 | 07:19 PM
bostock1957's Avatar
bostock1957
Default My .02 worth
When I put the trim ring on mine it was a little loose and noisy so I went down to the hardware store and got some rubber insulation that was in a thin strip form and wrapped around the light housing then put the trim ring back on, it doesn't show with the trim ring on and seals out moisture as well, might work for you also. Good Luck!
Bo
Old Mar 14, 2012 | 09:07 PM
cmancini26's Avatar
cmancini26
Thanks for all the helpful ideas
Old Mar 15, 2012 | 10:43 AM
johnjay's Avatar
johnjay
Try a commercial pump company, there a rubber o rings in every size imaginable.
Bobby12012
Oct 22, 2014 02:11 PM
billbuzz
Mar 11, 2014 08:53 PM
mswing1234
Jul 18, 2013 12:37 PM
SoonerSoftail
Feb 24, 2011 08:18 AM
shagnasty
Feb 21, 2010 09:47 PM
