Inner Tubes
Old Mar 16, 2012 | 09:26 AM
goblin127's Avatar
goblin127
Try american motorcycle tire. Best prices I've seen. I've been buying tires and tubes there for years.
Old Mar 16, 2012 | 09:33 AM
128auto's Avatar
128auto
Always replace the inner when I change tires, rind-on sealant as well. Don't forget to check rim tape, wear out from time to time.
Old Mar 16, 2012 | 09:53 AM
07bobber's Avatar
07bobber
i use the cheaper tubes also...
Old Mar 16, 2012 | 10:14 AM
macnab_sf's Avatar
macnab_sf
Ron Ayers has low cost on tubes, and they only have one kind, so easy to choose.
Old Mar 16, 2012 | 10:17 AM
Skid Lid's Avatar
Skid Lid
Funny how marketing works, and what we decide to take in and what we buck. The whole theory of tube replacement on every tire change is an OLD OLD one, and maybe back in the 60's & 70's this was the case, but now adays it just isn't. More often than not the stealer or indy will be sloppy taking off your old tire and pinch or rip your tube so in those cases well you have no choice. I have always changed my own tires with a pair of tire spoons, and my two hands. Modern tubes will last as long as you want them to, check the valve stem area and make sure there are no leaks/rust and go nuts. I know lots will say tubes are cheap or this or that but the reality is you are wasting money if you are changing the tubes on your bike every tire change. My $.02 from years of doing it myself.
Old Mar 16, 2012 | 06:26 PM
QehQeh's Avatar
QehQeh
I'll add another 2 cents to that. As long as the tube shows no signs of damage or deterioration, it's a waste to change it. I've taken wheels to two seperate Indies and both said that the tubes were still good, when they could have made extra money by selling me new ones.
Old Mar 16, 2012 | 06:56 PM
Skid Lid's Avatar
Skid Lid
Totally agree common sense goes a long way, we replace tires because they are worn out or damaged, same should go for the tubes, glad to see there are still some indys out there that are using common sense.
Old Mar 16, 2012 | 07:41 PM
stilup's Avatar
stilup
I went with a radial metz and a radial tube.
Radial tubes a big and very heavy duty. And not cheap either.
With a radial tire on a wire wheel I took the extra precaution and got the proper tube.
Using a size smaller in width is a plus in fitting the tube in the tire.
Old Mar 16, 2012 | 09:55 PM
zukeeper's Avatar
zukeeper
my *** is worth spending a few bucks on a new tube
Old Mar 16, 2012 | 10:55 PM
Skid Lid's Avatar
Skid Lid
If someone told you you had to replace your rims with every tire change would you?
Logic people, common sense
