Inner Tubes
Old Mar 15, 2012 | 05:57 AM
markp66's Avatar
markp66
Default Inner Tubes
Getting ready to put new tires on my wide glide. I have been told that I should put new tubes in at the same time. Looking at tires from motorcylesuperstore.com and there are so many different brands of tubes in a wide range of prices.
Anybody got any experience? I haven't bought tubes since the dirt bike days and we bought cheapest we could find back then.
Old Mar 15, 2012 | 09:37 AM
AK BAGGER's Avatar
AK BAGGER
I haven't had to buy tubes lately (like you said ...dirtbike days!). Even Momma's new 2012 Superglide Custom w/spokes are tubless (i wonder if the 2012 Wideglide is tubeless?). Regardless, since your bike is a 2011 and you are already in need of new tires ...chances are even if you bought cheap tubes they will last just fine until your next set of tires (next year??).
Old Mar 15, 2012 | 09:38 AM
'10 Wide Glide's Avatar
'10 Wide Glide
Personally I would but that's me
Old Mar 15, 2012 | 10:33 AM
JRK5892's Avatar
JRK5892
i ALWAYS replace the tubes... the wheel strips i replace ever 3 changes....
Old Mar 15, 2012 | 11:45 AM
markp66's Avatar
markp66
Any particular brand of tubes that you like?
Old Mar 15, 2012 | 12:11 PM
JRK5892's Avatar
JRK5892
the cheapest... hahaha i run metzler tires and whatever tubes i can put in... motorcyclesuperstore is 90% of where i get our tires from
Old Mar 15, 2012 | 08:18 PM
AK BAGGER's Avatar
AK BAGGER
to clarify my original post ...I didnt mean to imply that you should use the same tubes when you change you tires. Always get new tubes when you change tires. What I meant was ...even if you bought cheap tubes ...they will do just fine until your next tire change.
Old Mar 16, 2012 | 05:42 AM
markp66's Avatar
markp66
I had not thought of it that way, but you are probably right. If I put tires on once a year or so, the tubes should hold up that long. I will probably get some cheaper ones in a brand I have heard of and call it good.
Thanks
Old Mar 16, 2012 | 06:03 AM
LarryLives's Avatar
LarryLives
A tube and rim band is like 20ish bux at the dealer, I would change them, I just did my front tire with a new tube and band. IMO changem and no worries.
Old Mar 16, 2012 | 08:02 AM
02fx4dude's Avatar
02fx4dude
I had the indy put in drag specialties heavy duty tubes last time I had new tires put on, they were something like $10 each.
