Installing Brakes
Old Mar 16, 2012 | 10:51 PM
por2gezo's Avatar
por2gezo
Default Installing Brakes
does anyone know where I can go to watch a video or see a totorial on how to install brakes on my 06 street bob?
Old Mar 16, 2012 | 11:03 PM
soft 02's Avatar
soft 02
No but ask away.
Old Mar 16, 2012 | 11:11 PM
por2gezo's Avatar
por2gezo
I just took off my brake pads and am a little confussed ... what are the clips that you are all talking about ... do they stay in the caliper when you take pads ? do they come off with the pads ?
Old Mar 16, 2012 | 11:15 PM
soft 02's Avatar
soft 02
No they stay up in the caliper and you have to push a little bit to alighn the hole for inserting the pin bolts. Did they come out when you removed the pads?
Old Mar 16, 2012 | 11:23 PM
icecaps's Avatar
icecaps
Reading More Posting Less
https://shop.newcastlehd.com/part/99481-06a
Old Mar 16, 2012 | 11:28 PM
soft 02's Avatar
soft 02
Originally Posted by icecaps
Well that doesnt help him get his brake job done. But thanks.
Old Mar 16, 2012 | 11:32 PM
por2gezo's Avatar
por2gezo
no they stayed up in the caliper. and its hard as **** to get the pads back in any tricks to getting the new pads in so that you can get the bolts back in.
Old Mar 16, 2012 | 11:35 PM
soft 02's Avatar
soft 02
Are they OEM? Harley.
Old Mar 16, 2012 | 11:38 PM
soft 02's Avatar
soft 02
This is also a good time to take an old tooth brush to your caliper pistons to clean up grime because when you install new pads you are going to push those pistons back in the bore with that grime on them.
Old Mar 16, 2012 | 11:43 PM
icecaps's Avatar
icecaps
Here's the link to MotorcycleMetal's "Motorcycle Brake Maintenance"
http://www.motorcyclemetal.com/Download8.html
