Clutch issue
Old Mar 17, 2012 | 09:57 PM
GrovenSportster's Avatar
GrovenSportster
Default Clutch issue
I've got a 2012 Fat Bob with 444 mi. on it. It has a V&H Pro Pipe, SE air box conversion and the Supertuner Pro down load on it. The bike hauls *** but there's one problem. I've noticed the clutch slipping when I run it through the gears in spirited fashion. Are the clutches in these things so weak that a little tuning and a pipe could overcome them? I'm not liking this at all! Perhaps they have weak springs?
Old Mar 17, 2012 | 10:22 PM
axslingerw's Avatar
axslingerw
More likely they didn't get it adjusted right at the stealership. Check your freeplay against the manual and see if it is enough. too little freeplay = clutch not fully engaged. Too much freeplay = clutch not fully released when lever pulled.
Old Mar 19, 2012 | 06:26 AM
GrovenSportster
That crossed my mind. I'll give it a look. Thanx.
Old Mar 19, 2012 | 07:39 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Yeah like axslingerw said. These wet clutches are tough as nails and practically bullet proof. I've had my fxdc since last August and I collapse the cable and check and adjust if necessary the clutch evertime I service her.
higbee76
Jul 23, 2017 02:55 PM
chopperdude
Nov 8, 2010 06:45 PM
skarouba
Apr 8, 2010 05:31 PM
HogNewbie
Sep 6, 2009 06:54 AM
mriddle
Jul 18, 2007 11:39 AM
