Gauges-Ok what am I missing here?
Old Mar 21, 2012 | 02:36 PM
HYPR's Avatar
HYPR
Default Gauges-Ok what am I missing here?
Ok, what am I missing here? Is there a specific reason why I can't just install Auto-Meter ProComp gauges into my Road Glide Fairing that I am installing on my FXDF? I mean why pay $140 for the Oil Temp Guage when you can pick up Auto-Meter ProComp electical gauge for less than half that amount? Even if it means the sending units are a smaller thread diameter the only additional cost is for a different sized adapter (according to the installation instructions the HD gauges use an adapter as well) which is less than $3.
In addition there is a greater variety of Gauges available in the aftermarket.
Your thoughts?
Bob
Old Mar 21, 2012 | 02:56 PM
Chicago Ken's Avatar
Chicago Ken
I'm almost certain that Auto-Meter supplies Harley with their gauges. Talked to an Auto Meter rep at the Summer Nationals last year and he told me that they made some of Harley's COV and SE gauges.
I would try getting info from Auto-Meter on what you need to get it to work in your app. if your dealer tells you they can't help you. I have the feeling the dealer will want to sell you another gauge at $150 rather than just selling you the sending unit.
Old Mar 21, 2012 | 05:30 PM
HYPR's Avatar
HYPR
Well I went ahead and sent an inquiry to Auto Meter and promptly received a response as follows:
Hello,
Technically, they would work just fine; however I would be worried about them holding up however. Our standard automotive gauges are not intended to be outside exposed to the elements such as sunlight or water. They are not water resistant yet alone water proof. They are also not built to the same vibration standards as our ProCycle line, however I know there isn't anything as far as gauges beyond a speedometer or tach in that particular series.
I have seen people do it, I myself have a Voltmeter on my bike, but I understand the risks associated with doing so and I accept full responsibility for it if it fails as I am using it outside of the parameters for which it was wasn't desired, recommended, or tested for. Our automotive gauges are not warranted against water damage and they very well may not hold up to being mounted/installed on that kind of application due to other factors such as vibration even if they don't get exposed directly to rain. We can not recommend installing them on a bike just due to them not being designed to do so.
Best Regards,
John
Tech/Service
Auto Meter Products
413 W Elm St.
Sycamore IL 60178
1-866-248-6357
Oh well back to the drawing board!
Bob
1of2
"The Florida Crew"
40
Sep 9, 2010 09:34 PM
