True Track Help!!
Old Apr 7, 2012 | 08:00 PM
secondlook's Avatar
secondlook
Default True Track Help!!
Had my mechanic install my Arnott air ride and true track and now I am getting just the most awful vibration 1-3 gears (when torque is highest) feels like engine and tranny just arent meshed or something its the entire bike really rough shake/vibration. Its really bad, any things I can look over or recommend to double check?
Old Apr 7, 2012 | 08:29 PM
thedonthere's Avatar
thedonthere
Doesn't the true trak essentially make the motor solid mounted after you install it? Seems to me that it does away with the dampening action of the rubber motor mounts.JMO.This isn't the first time I have heard this.
Old Apr 7, 2012 | 09:29 PM
secondlook's Avatar
secondlook
I'm about to uninstall if this continues..I can't imagine everyone is having this problem but its beyond tolerable.
Old Apr 7, 2012 | 09:50 PM
Bagger Jim's Avatar
Bagger Jim
The True Track only stabilizes the engine and transmission assembly laterally, that is to keep it from moving sideways. The rubber mounts will still function as intended. You will feel a very slight more vibration because it is locked side to side, but most of the vibration generated by the engine is in the other direction if that makes sense. You might check if the unit was installed properly. Sounds like the "tie rod ends" might be adjusted too tight one way or the other. The rods should be adjusted in a neutral position, that is not trying to pull the engine to the right or left. If you pull one of the bolts that secures the end of the rod, it should be lined up with the mounting hole with no tension on it either to the right or left. Don't know if I'm explaining it correctly, but I hope you get the drift. I did notice a little more vibration with mine, but I mean a VERY little. I don't think most people could tell the difference. Mine works as advertised and is one of the best mods I've done.
Old Apr 8, 2012 | 11:31 PM
AK_Rider50's Avatar
AK_Rider50
I installed a true track this past winter and although I haven't put more than 20 miles on the bike due to snow on the roads, I haven't noticed any change in vibration. I did put my bike up in October for the winter so it's been along time since I've ridden it but I think I would notice a change in the bike like that. Like WGJC said, the bolts into the true track rods should be a "drop fit", no shear tension on them when you bolt it up. I would check that first then do an alignment check on all three points.
Old Apr 9, 2012 | 12:14 AM
DTDK's Avatar
DTDK
i would give true track a call, and your indy
Old Apr 9, 2012 | 01:27 AM
hboat's Avatar
hboat
X3! on what WGJC said. I couldn't have said it better or given a more complete explanation. If you push your bike hard in the corners, you'll love TT.
Old Apr 9, 2012 | 06:52 AM
Romeo's Avatar
Romeo
The only thing I can add here is to make sure your bike is vertical when you check those tie rods. If it's leaning on the jiffy stand, you won't be able to check or adjust it properly.
Old Apr 10, 2012 | 10:44 PM
secondlook's Avatar
secondlook
Got it adjusted and bike rides great!!! Air ride and true track baby!
Old Apr 11, 2012 | 04:41 AM
Bagger Jim's Avatar
Bagger Jim
Glad you got it worked out. Bike looks good!
