Please help Bike stalls
Old Apr 14, 2012 | 07:24 PM
Sidewind75's Avatar
Sidewind75
Default Please help Bike stalls
Good evening everyone. I have a problem my bike wont start unless i wiggle the gas hose coming out of the bottom of the tank. it will sit there and idle fine even can get moving but as soon as i try to use the throttle for more gas it will stall and not start again untill i wiggle that hose again.. the tank is full and i do not have any tools on me atm any ideas would be much apreciated
Old Apr 14, 2012 | 07:40 PM
maddghost's Avatar
maddghost
Try this it worked for me last year. Turn the ignition off and open the fuel cap , just to relieve pressure. Now push lightly upwards on the bottom of your fuel line and feel the loose it has. When you feel that your good to push up on the quick disconnect (silver par) that will separate the two. Now carefully re-insert the fuel line and it should fire right up. Apparently the cure is to change out the quick disconnect, the part is about 75$ in the states.
Old Apr 14, 2012 | 08:50 PM
4trax's Avatar
4trax
Yep, as stated above. It's a bad fuel valve. They have been having issues with them, no specific models. Just one of those things that go on. Just pop it off like you do an air chuck on an air hose. Then pop it back on and it should fire up and run, but it will quit again who knows when??. You need to replace it.
Old Apr 14, 2012 | 09:04 PM
Sidewind75's Avatar
Sidewind75
Thanks guys that worked so glad its nothing to serious just hope it will keep running for the beautifull weekend we are going to have
Old Apr 14, 2012 | 09:13 PM
maddghost's Avatar
maddghost
Dude i'm so glad you got it! If it happens again just pop it again! mine's been going on close to a year now! Ya never know when it will cut off, I have all the parts at my H-Dealer just waiting for some unseen moment when i will bring it in for them to change it out. It's not that it's that hard of a job but if something fuxxs up I'd rather it be in their hands!
Musician
Jul 3, 2015 12:10 PM
texasmail1962
Aug 30, 2011 01:08 PM
cwsharp
Jul 8, 2010 08:43 AM
wyoming55
Jun 6, 2009 09:18 AM
doughboy
Exhaust System Topics
May 27, 2005 06:09 PM
