Handshift/Jocketshift
Old Apr 23, 2012 | 04:12 AM
onemyndseye's Avatar
onemyndseye
Default Handshift/Jocketshift
Probably lack of sleep but I've been thinking the past few days of adding a hand shifter to my FXD basically just for those times when I need a new gear but my feet are stretched out on the hwy pegs. Seems a useful mod and bring alittle Old-schoolness with it
For my needs I see no reason to need a clutch.. Just the addition of a hand shifter. Seems easy enough to find/make/mod one that will attach and leave my current shifter in place.
... anyone else done this? Overkill? Lack of sleep? Get a real job and quit posting so much? Shut the fk up and ride my damn bike?
Old Apr 23, 2012 | 04:58 AM
Jeff W's Avatar
Jeff W
So your just going to bang the gears without a clutch? IFC would not do that myself but you pay for your bike not me.
Old Apr 23, 2012 | 05:20 AM
onemyndseye
I shift quite alot without the clutch as I imagine alot of others do... nice and smooth without `banging` anything I know most everyone I ride with shifts clutchless at times... Even when Im "banging" through gears I barely clutch.... two finger slap while shifting then roll the power. Hell the Dynojet Power Commanders have a addon called a "Quick Sifter" that is DESIGNED entirely for shifting without the clutch.
The key is... the same as any manual shift tranny... you must UNLOAD the power before shifting. That means letting off the throttle. Dynojet's quickshifter does exactly this - It cuts you ignition for a split second while you shift so u dont bork your tranny while making ur drag run
http://www.powercommander.com/powerc...k_shifter.aspx
You only NEED a clutch when stopping and taking off (or friction zoning ofc... but thats a complete new topic). Shifting can be done quite smoothly and safely without the clutch lever ever being touched.
The situation where i think it would be handy is in cases where your cruising in 6th and need to downshift for say a hill climb (bridge, interchange, hill etc) for a short bit before returning to 6th. Sorta a pain to move back to the mid pegs for something like that.
.... that being said - yes I know I can downshift with my heel and upshift with the side of my boot. .. beside the point
FlatIron
Feb 14, 2018 02:49 PM
09xl883l
Sep 26, 2012 10:59 PM
hogrider09
Apr 17, 2010 06:43 PM
michaelbarry
Mar 30, 2008 08:20 PM
glebo
Aug 7, 2007 08:58 AM
