XIEDs
Old Apr 30, 2012 | 01:13 PM
TMO's Avatar
TMO
Default XIEDs
Wanting to add xieds to my 12 FXDB and was wondering if i go to a shop that sells them how do you pronounce it? Not trying to be silly or anything just curious the correct way to say it?
Old Apr 30, 2012 | 01:19 PM
MADDOG187's Avatar
MADDOG187
they are initials for extreme , inline , enrichment , device , so X.I.E.D,s is correct , but ive heard people pronounce them zeeds , take your pick
Old Apr 30, 2012 | 01:29 PM
DSnoopy's Avatar
DSnoopy
LOL - I.E.D does not go over too well with most people I know! Let alone Extreme.
Old Apr 30, 2012 | 01:38 PM
woznotwoz's Avatar
woznotwoz
Quite afew people seem to swear by them, but I think they are very expensive for what they are..... basically a piece of wire, some plugs and a resistor.
Old Apr 30, 2012 | 01:55 PM
TMO's Avatar
TMO
Thanks maddog!
Old May 1, 2012 | 12:42 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I don't believe you can get them in a shop. Have to get them from NightRider.
Old May 1, 2012 | 01:09 AM
xantasm's Avatar
xantasm
You can order them online, as stated you likely won't find any shops that carry them. I would also not waste the money, time, or effort in even trying to get a shop to get them and install them for you. If you want them, order them and plug them inline to your wiring. It's that simple and paying someone else to do that for you is a needless waste of money.
http://sales.nightrider.com/2012_c_88.html
They trick your FI system into thinking its getting a false reading so that your air fuel ratio is adjusted to run richer than the stock programming would. So many would consider them not a good solution for the money but sometimes a band aid fix works till you can afford a high quality tuner. Thats a choice your going to have to make, but I would suggest reading a lot about the subject so you can make up your own mind without all of the opinions of others.
Old May 1, 2012 | 02:43 AM
DCLXVI's Avatar
DCLXVI
You may also want to make certain if they fit a 2012. The electrical system on those bikes is different from the previous years.
Old May 1, 2012 | 03:24 AM
art0565's Avatar
art0565
With the bike running richer do the spark plugs get fouled up quicker?
Old May 1, 2012 | 04:52 AM
maddghost's Avatar
maddghost
@ art In a word .....No!
@TMO Look up nightrider.com on google and Steve, mr. nightrider has all the info posted on his site. you will come to a page describing the differend ied xied and vieds for your year / model bike. You could also join his forum and get your info straight from the man who designed them for HD bikes. He will tell you himself they are a quick cheap and dirty fix to the epa regs HD have no choice but to comply to. It is what it is. As others have stated save some money by waiting for a real tuning device that will allow adjustments to be made further on down the road!
