bike lift
Old May 2, 2012 | 03:02 PM
'10 Wide Glide's Avatar
'10 Wide Glide
Question bike lift
this one is mainly directed to someone in canada I just bought this bike lift on sale for $89 http://www.canadiantire.ca/AST/brows....jsp?locale=en but I haven't tried it yet... My question is does anyone have this lift & do I need to modify it? or will it work with out modifying it?
Old May 2, 2012 | 04:09 PM
slider1156's Avatar
slider1156
You will need a set of jacking blocks from H.D or make a set so your not jacking on the oil pan on the bottom of the motor. Also it looks like it has a u shaped tie down point on the front like mine did. The u shaped part will hit on your kickstand spring when you push it in under the bike. I cut it off in the middle so I can still use it to put on a tie down to hold the bike in place when working on it. Thats about what I paid for mine on sale. Its a good jack
Old May 2, 2012 | 05:38 PM
SuperFastGlide's Avatar
SuperFastGlide
it will work fine... just needs a simple mod... check this great thread from SC-Longhair
https://www.hdforums.com/forum/dyna-...ification.html
Old May 3, 2012 | 10:25 AM
8541hog's Avatar
8541hog
+1 on that, that lift looks like it is the Sears Red, and the mod is a piece of cake to do,
Old May 3, 2012 | 10:52 AM
HD-MC's Avatar
HD-MC
I got the same lift on sale at CT and was wondering the same thing it's still in the box since last october LOL good info. I might have to try the mod or get the block..
Old May 3, 2012 | 10:55 AM
8541hog's Avatar
8541hog
Forget the blocks, they are a pain compared to the mod, and the mod is much more stable.
Old May 3, 2012 | 01:48 PM
HD-MC's Avatar
HD-MC
Thanks for mentioning will have to do the mod I guess
Old May 3, 2012 | 02:16 PM
128auto's Avatar
128auto
Get the jacking blocks from HD, must have for Dyna, very easy to use.
I have an OTC stinger jack, by far the lowest jack in the market.
http://www.amazon.com/OTC-1545-Motor.../dp/B000OCHCIW
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old May 3, 2012 | 04:40 PM
'10 Wide Glide
Thanx for the info guys, I did know about the sears jack mod but I wasn't sure if it was done to this jack before by someone.
I guess I'll put it together this weekend & see what would work best the mod or the blocks
Old May 3, 2012 | 06:24 PM
LoBoT's Avatar
LoBoT
Thanks you guys. Excellent mod on the lift. It works like a charm. One issue that may apply to my bike only. My clutch cable runs under the corner of the engine case (see pic) It gets pinched slightly by the forward lift bar unless pulled to the side . Easy to remedy with a temporary tie back but thought I'd mention it none the less.
Attachment 248259
