Air Box Sensor Wire?
Old May 9, 2012 | 03:11 PM
retxpres's Avatar
retxpres
Default Air Box Sensor Wire?
I am ready to change my air filter on my bike and noticed on the back plate there is a quick disconnect that goes to a sensor. The new Stage One air box has no provision for the sensor. WTF.... Has anyone else seen this... Please inform!
Old May 9, 2012 | 04:12 PM
Stag556's Avatar
Stag556
According to instructions with the stage one filter, that connector is no longer utilized and a clip should be included with the new filter to place it up and out of the way.
Old May 9, 2012 | 05:19 PM
Foxster's Avatar
Foxster
That's not usually connected to anything on domestic (US) models. You sure its connected up?
On non-US models it drives a little flappy paddle in the front of the air intake that reduces intake noise to meet a draconian standard in some backwater country (probably mine).
Old May 9, 2012 | 05:29 PM
Stag556's Avatar
Stag556
There was a connector connected to the rear of my stock air box. It's not utilized with my stage 1 air cleaner.
Old May 9, 2012 | 05:36 PM
Foxster's Avatar
Foxster
Umm. Might be just a dummy connector on the stock A/C to hold the connector - unless they started fitting the active air intake to US models now. If they have, then it needs an eliminator plug when the stock A/C is removed otherwise the ECU throws codes.
Old May 9, 2012 | 05:49 PM
128auto's Avatar
128auto
I notice that but don't know what that is, guess it isn't important, I had mine hanging there with a zip tie.
Old May 9, 2012 | 05:50 PM
wyldspirit's Avatar
wyldspirit
On the rear of the plastic breather plate there is a holder that it locks into. Per my dealer they told me that the stage 1 kit should have come with a new clip and a plug cover. The clip is pretty much worthless, so use a zip tie and the cover is free from the dealer but have to ask for it
Old May 9, 2012 | 06:04 PM
retxpres's Avatar
retxpres
Ok, the wire just went into a terminating cap on the back of the stock air cleaner housing. I removed the cap, placed it back on the wire and zip locked it up and out of the way. I have no idea what the purpose of this wire is for. At first I thought it was a sensor, not a cap.
Old May 9, 2012 | 10:25 PM
ackman1968's Avatar
ackman1968
See post #3, they use the same harness in domestic and export bikes. The terminal is for export bikes.
CRZYLGZZ
Sep 6, 2009 09:43 AM
GeorgeH
Aug 26, 2008 02:53 PM
crock921
May 12, 2008 08:14 AM
yodal
Aug 13, 2005 03:06 AM
Johnny
Exhaust System Topics
18
Apr 27, 2005 01:02 PM
